in order to get a full picture how Geoserver handles GetFeature-requests for feature types which are identified or not by full namespace
I have analyzed Geoserver’s current stable version 2.3.3 by sending several alternative GetFeature-requests for WFS version 1.0.0 and 1.1.0.
For a few constellations Geoserver reacts differently from what I think a user/client would expect which
I like to illustrate here (using the default geoserver tasmania dataset):
The request scenarios and their particular HTTP-GET requests (here for version 1.1.0) are the following:
- request with a typeName without xml-prefix/ without namespace declaration
expectation: should return a GML result
- typeName with known xml-prefix but without namespace
expectation: GML result
- typeName with unknown xml-prefix
expectation: should throw a service exception
- typeName with known xml-prefix and corresponding valid/registered namespace
- typeName with unknown xml-prefix but prefix/namespace mapping to a valid namespace
- typeName with xml-prefix which is mapped to an unknown namespace
My issues/questions:
a) all HTTP-GET responses are correct but one. In scenario 5 for WFS interface version 1.0.0 I get an “unknown Namespace”-error.
I am aware of the fact that the “namespace”-parameter is classified as a common parameter not before WFS-spec 1.1.0, so handling this parameter in Geoserver WFS 1.0.0 code is not
obligatory and would only be a backward-compatibility matter and a user feature
b) sending an HTTP POST request for scenario 1 to WFS-interface 1.0.0 results in
an error message: “Could not locate {http://www.opengis.net/wfs}tasmania_roads in catalog.”
The request is:
<wfs:GetFeature service=“WFS” version=“1.0.0” outputFormat=“GML2” xmlns:wfs=“http://www.opengis.net/wfs” xmlns:ogc=“http://www.opengis.net/ogc”
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xsi:schemaLocation=“http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd”>
<wfs:Query typeName=“tasmania_roads”>
</wfs:Query>
</wfs:GetFeature>
It looks like Geoserver takes the first namespace, namely the WFS-namespace? Or is it the default namespace according to the spec?
c) sending an HTTP POST request for scenario 3 both to WFS-interface 1.0.0 and 1.1.0
I surpringly get the GML-results, no error message
<wfs:Query typeName=“tip:tasmania_roads”>
</wfs:Query>
</wfs:GetFeature>
Here, Geoserver resolves only the local part of the requested feature type and does not care about the unknown xml-prefix.
I would appreciate any feedback.
Sven
