I'm having trouble (as always) getting the logging level changed, I added the following line to my logging.properties file in the Tomcat5.5/conf directory, but I don't get the logs.
org.geotools.data.mysql.level = FINEST
I'll see if I can see use the debugger to stop execution and find the problem.
Richard Shaw
¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,ø¤
Richard Shaw
Technical Design Authority - Information Solutions Consultancy
Intelligent Transport Systems
Atkins Highways and Transportation
Woodcote Grove, Ashley Road, Epsom, Surrey, KT18 5BW
Tel: +44 (0) 1372 756407
Fax: +44 (0) 1372 740055
Mob: 07740 817586
E-mail: richard.shaw@anonymised.com
www.atkinsglobal.com/its
-----Original Message-----
Sent: 10 November 2006 21:08
To: Shaw, Richard A
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Has the MySQL data source been broken
Probably. I'm the maintainer for MySQL, and I've been very negligent.
That's why it's a download and not included in GeoSever by default.
The namespace thing is a bit odd, though actually I remember there needs to be some work on namespaces.
For the second, turn on 'fine' logging and see what the sql sent to the database actually is, and how that lines up with the encoder.
None of this should be too hard to fix, I can try to find some time to fix it myself, or you can take a shot at it, as it sounds like you've got some experience with the ms-sql now. I'd be happy to direct you and help you work through error messages.
best regards,
Chris
Shaw, Richard A wrote:
I've just installed the geoserver 1.4.0 RC3 and I get 2 errors with
the MySQL datasource -The first is that it seems to be using the namespace that I put my
datasource into as the table name so I have to ensure that the
namespace and the tablename match,After doing this the second error is -
DarlingtonITN:links
org.geotools.data.DataSourceException: SQL Error building FeatureType
for links Syntax error or access violation message from server: "You
have an error in your SQL syntax; check the manual that corresponds to
your MySQL server version for the right syntax to use near
'://www.atkinsglobal.com/darlington.links WHERE 0=1' at line 1"I need to use 1.4.0 because the SQL Server data source that I have
created was done from the latest source code and will not work with
1.3.0Richard Shaw
*Richard Shaw*
Intelligent Transport Systems*Atkins* *Highways and Transportation* Woodcote Grove, Ashley Road,
Epsom, Surrey, KT18 5BWTel: +44 (0) 1372 756407
Mob: 07740 817586
E-mail: richard.shaw@anonymised.com_www.atkinsglobal.com/its_ <http://www.atkinsglobal.com/its>
*This email and any attached files are confidential and copyright
protected. If you are not the addressee, any dissemination of this
communication is strictly prohibited. Unless otherwise expressly
agreed in writing, nothing stated in this communication shall be
legally
binding.* <http://www.blackspider.com/>!DSPAM:1003,45544b05188487731818748!
--- Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=1216
42!DSPAM:1003,45544b05188487731818748!
--_______________________________________________
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1003,45544b05188487731818748!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
This message has been scanned for viruses by MailControl - (see http://bluepages.wsatkins.co.uk/?4318150)
