[Geoserver-devel] Have data directories on trunk become backwards incompatible?
today I've opened a data dir with 2.0.x, then with GS trunk,
and after some minutes again with 2.0.x and I was greeted by
a stack trace (see the end of the mail).
Is the persistence on trunk/2.1.x become backwards incompatible
with 2.0.x? If that is actually so, any idea of how to manually
modify the data dir contents to get back a working 2.0.x data directory?
02 feb 14:52:52 ERROR [mortbay.log] - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,src/main/webapp}
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geoServer' defined in URL [file:/home/aaime/devel/gs2.0.x/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: com.thoughtworks.xstream.converters.ConversionException: globalServices : globalServices : globalServices : globalServices
---- Debugging information ----
message : globalServices : globalServices
cause-exception : com.thoughtworks.xstream.mapper.CannotResolveClassException
cause-message : globalServices : globalServices
class : org.geoserver.config.impl.GeoServerInfoImpl
required-type : org.geoserver.config.impl.GeoServerInfoImpl
line number : 22
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
  at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
  at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
  at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
  at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
  at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
  at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
  at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
  at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
  at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
  at org.mortbay.jetty.Server.doStart(Server.java:222)
  at org.geoserver.web.Start.main(Start.java:66)
Andrea Aime
OpenGeo - http://opengeo.org
I would say it has become forward incompatible yes :slight_smile:
And yes this is somewhat of a pain with xstream. It would be nice if we had a way to tell it to ignore this case, aka not fail when there is a field in some output that has no corresponding field in a class.
If you want to modify the data directory directly simply remove the globalServices element in global.xml.
We could also just add a "dummy" globalServices field to GeoServerInfo on 2.0.x. It would never get used or called but would us to be forward compatible.
-Justin
On 2/2/10 8:56 AM, Andrea Aime wrote:
cause-exception :
line number : 22
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
Justin Deoliveira
This page has a mention of that:
http://xstream.codehaus.org/faq.html#Serialization_newer_class_versions
It seems there is a test that implement that kind of unknown field
skipping.
I'm sure I've seen an announcement of a library for xml configuration
persistence that actually handled explicitly such problems, I think
it was implemented by a German company, but for the life of me I
cannot find the site anymore... Oh well, was just an interesting link
anyways.
Andrea Aime
anyways.
Oh, found it. It's an interesting read:
http://serialization.cedarsoft.org/
Andrea Aime
anyways.
Interesting indeed. Too bad it was not around when we chose xstream :slight_smile: Seriously though the first class support for versioning seems exactly what we need. Oh well... maybe for GeoServer 3.0 :wink:
Justin Deoliveira
skipping.
And here we go with a patch based on that XStream test:
http://jira.codehaus.org/browse/GEOS-3797
Andrea Aime
