[Geoserver-devel] Hazelcast version upgrade
Dear community,
I want to propose and contribute Hazelcast version upgrade for the GeoServer repository, since the current version is now a bit old (3.11), has some known vulnerabilities and I’m working on create and contribute a Hazelcast data store using some latest version without being in conflict with existing modules.
A quick search throws only wps-cluster-hazelcast uses 3.11 version and community hz-cluster uses a custom 3.8.3:
./pom.xml: <hazelcast.version>3.11.1</hazelcast.version>
./pom.xml: com.hazelcast
./pom.xml: hazelcast
./pom.xml: ${hazelcast.version}
./pom.xml: hazelcast-spring
./pom.xml: release/ext-wps-hazelcast.xml
./release/pom.xml: gs-wps-cluster-hazelcast
./extension/wps/pom.xml: wps-cluster-hazelcast
./extension/wps/wps-cluster-hazelcast/pom.xml: gs-wps-cluster-hazelcast
./extension/wps/wps-cluster-hazelcast/pom.xml: Web process status sharing with Hazelcast
./extension/wps/wps-cluster-hazelcast/pom.xml: com.hazelcast
./extension/wps/wps-cluster-hazelcast/pom.xml: hazelcast
./community/hz-cluster/pom.xml: GeoServer Hazelcast Clustering Module
./community/hz-cluster/pom.xml: <hazelcast.web.version>3.8.3</hazelcast.web.version>
./community/hz-cluster/pom.xml: com.hazelcast
./community/hz-cluster/pom.xml: hazelcast
./community/hz-cluster/pom.xml: hazelcast-spring
./community/hz-cluster/pom.xml: hazelcast-wm
./community/hz-cluster/pom.xml: ${hazelcast.web.version}
./web/app/pom.xml: wps-cluster-hazelcast
./web/app/pom.xml: gs-wps-cluster-hazelcast
I checked GeoTools and there is no hazelcast dependency as far as I can see.
I see the work here is:
  • Upgrade version on main repo
  • Test wps-cluster-hazelcast works fine with the upgrade
There is any other concern to have present, something else to check or any foreseen consequence?
Fernando Mino
Visit http://bit.ly/gs-services-us for more information.
Fernando Mino
Software Engineer
@fmy2kec
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
