I built Geoserver with the -Pwps flag, and have also tried unzipping the extension into the geoserver/WEB-INF/lib directory.
Here is my build info:
Though in the course of trying to build this I have also used 2.6 (the one I started with) and 2.7 (downloaded as a WAR file)
My Hello World Class, pom.xml and applicationContext.xml files are all copied directly from the above webpage.
I have searched for the error, but have found no evidence of it on Google or the mailing lists. Am I doing anything obvious wrong?
Thanks very much,
Jonny.
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight. http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Thanks very much,
Jonny.
Thanks very much,
Jonny.
Thanks very much,
Jonny.
Thanks very much,
Jonny.
Thanks very much,
Jonny.
Deep dive visibility with transaction tracing using APM Insight. http://ad.doubleclick.net/ddm/clk/290420510;117567292;y_______________________________________________
Geoserver-devel mailing list
Geoserver-devel@anonymised.comnet https://lists.sourceforge.net/lists/listinfo/geoserver-devel
