[Geoserver-devel] Help implementing an OWS service
It is appreciated if you can keep all questions on the public mailing list and not email developers directly.
How are you running GeoServer? Are you sure the jar is in the correct location to be placed on the classpath? Can you post the jar somewhere to take a look at. Thanks.
-Justin
On Wed, Jan 8, 2014 at 9:38 PM, <hufei68@anonymised.com…> wrote:
Hi Justin,
I’ve been using the guide at
http://docs.geoserver.org/latest/en/developer/programming-guide/ows-services/implementing.html
to create the “hello” ows service, but am having some troubles. When I
request the sayHello method from the URL, I get the following exception:
<ows:ExceptionReport version=“1.0.0”
xsi:schemaLocation=“http://www.opengis.net/ows
http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd”>
<ows:Exception exceptionCode=“InvalidParameterValue”
locator=“service”>
ows:ExceptionTextNo service: ( hello )</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
I’ve searched the mailing list briefly to find a solution, but the answer
I’ve seen frequently come up is to make sure the applicationContext.xml is
included in the final jar archive. I’ve made sure it is there, and am not
sure how to troubleshoot this further. Any help would be appreciated.
Fei
Sent from http://geoserver-devel.821594.n3.nabble.com
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
