[Geoserver-devel] Help me extend GeoServer to work with Microsofts Virtual Earth
Microsoft's Virtual Earth allows to specify a url for a custom tile source.
It then makes the request using the Virtual Earth tilename. You can reverse
engineer the tile name to calculate the bbox parameters. I started using
this article... http://www.viavirtualearth.com/vve/Articles/WMS.ashx
http://www.viavirtualearth.com/vve/Articles/WMS.ashx I then ported it to
java to be servlet and class to take the virtual earth tile and make the
correct wms request to GeoServer. Here is my code (btw I am a java newbie so
I need some help here) it is a seperate web app that acts as a proxy to
Geoserver. I wanted to integrate it into the Geoserver application but my
inexperience (esp with maven) limited me.
http://www.nabble.com/file/p10919945/index.jsp index.jsp
http://www.nabble.com/file/p10919945/vetiletowms.java vetiletowms.java
http://www.nabble.com/file/p10919945/vetilebox.java vetilebox.java
it currently works but I know someone here can make it really work better.
Is anyone interested I probably wouldn't be much help but I would really
like to learn by seeing how it is done.
Thanks
CMH
FYI I have posted a similar message with tilecache boards.
I know that there is a summer of code project to recreate tilecache in java
so this would be really cool to integrate this into it.
View this message in context: http://www.nabble.com/Help-me-extend-GeoServer-to-work-with-Microsofts-Virtual-Earth-tf3854313.html#a10919945
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
oops.. in the servlet vetiletowms.java I was using regular expressions to
grab the tile name from the request url but then I changed the javascript in
the index.jsp to put the tilename into a tile= parameter. So if anyone is
looking at it, the regular expression part doesn't do anything but isn't
commented out.
Sorry about that
source. It then makes the request using the Virtual Earth tilename. You
can reverse engineer the tile name to calculate the bbox parameters. I
started using this article...
so I need some help here) it is a seperate web app that acts as a proxy to
Thanks
CMH
java so this would be really cool to integrate this into it.
View this message in context: http://www.nabble.com/Help-me-extend-GeoServer-to-work-with-Microsofts-Virtual-Earth-tf3854313.html#a10919994
Hi Cole,
Very cool!! The contribution is much appreciated. Even if the code does
need some work or fine tuning to integrate into GeoServer I am sure it
will serve as a great base. I have created a task in the bug tracker to
track this and attached all the code to it.
http://jira.codehaus.org/browse/GEOS-1121
Thanks again.
-Justin
Thanks
CMH
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
