[Geoserver-devel] Help needed: showing messages both at top and bottom of UI pages
a common complaint about the UI is that error messages are showing only at the top,
making them hard to find on small screens and/or when the page is not scrolling up upon
submit (ajax submits).
Now… how about this instead?
Inline image 1
Pull request here:
https://github.com/geoserver/geoserver/pull/2701
However… I’ll need some help to make it “right”:
  • The change touched several pages, can we tag-team to test them? (I’ve checked a few already with no issues)
  • Some community modules were affected that I’m not that familiar with, can respective interested parties have a look at the changes and see if they work?
Andrrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I almost prefer it near the apply / submit buttons where the action just occurred.
(attachments)
Jody Garnett
Andrea,
I tested out the changes for the GeoGigSettingsPage changes and it looks fine to me. I didn’t test much of the other changes however.
(attachments)
On Tue, Jan 2, 2018 at 7:33 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Inline image 1
Pull request here:
Andrrea
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Erik Merkle
Software Engineer | Boundless
On Tue, Jan 2, 2018 at 4:08 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
occurred.
You mean, on the same line as the buttons? That would require a change in
each and every page (since they do provide their own buttons, each in their
own way).
So, no, that's too much work :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
I mean I like it at the bottom of the page (more than the top), since that is closer to where the apply and submit buttons are.
On 2 January 2018 at 07:37, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
You mean, on the same line as the buttons? That would require a change in each and every page (since they do provide their own buttons, each in their own way).
So, no, that’s too much work :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Jan 2, 2018 at 5:47 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Some pages have regular (non ajax) submits which cause the page to be
reloaded fully and move to the top.
So having it both at top and bottom is important.
Sorry Jody, often it's not clear if you're just chit-chatting or if you are
asking for changes...
Ing. Andrea Aime
@geowolf
Technical Lead
Thank you Erik, much appreciated.
(attachments)
On Tue, Jan 2, 2018 at 4:23 PM, Erik Merkle <emerkle@anonymised.com…> wrote:
Andrea,
Erik Merkle
Inline image 1
Pull request here:
Andrrea
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel@anonymised.comrge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
