[Geoserver-devel] [help]SVG appears not as same as other formats
Hello,
  I'm using GeoServer and i've meet a problem.
  It seems that the result of wms queries with "Format=image/svg+xml" is not the same
as jpeg or png. The svg result is colorless, and the shapes are also different. Is it my fault or a bug or GeoServer just doesn't implement it?
  Thanks a lot
No, it's not you. Style support is not yet available for SVG. We hope
to improve this in the future. The contributor who wrote the code just
did style transformations on the client side. So it will return the
features, but if you want them to look good you need to do it yourself.
Chris
Quoting ²Ì´í <stripper@anonymised.com>:
Hello,
is not the same
implement it?
  Thanks a lot
This SF.Net email is sponsored by: YOU BE THE JUDGE. Be one of 170
Project Admins to receive an Apple iPod Mini FREE for your judgement
on
who ports your project to Linux PPC the best. Sponsored by IBM.
Deadline: Sept. 24. Go here: http://sf.net/ppc_contest.php
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
