[Geoserver-devel] [help]SVG appears not as same as other formats
Yes, that will work, and has been indeed been done before. There is
some code in GeoTools (our main library) to do this, it's in a module
called svgsupport I believe - it was in module/main, but was going to
move to ext/ or demo/ (of the geotools code base -
http://svn.geotools.org/geotools).
The reason we don't use it is because it is _slow_ in our tests. That's
why Gabriel wrote the current svg support, it writes directly from the
gt2 feature model. But let us know if it is faster and supports your
needs - perhaps we could consider rolling it into geoserver. I
personally have not tested it.
best regards,
Chris
Quoting ²Ì´í <stripper@anonymised.com>:
Chris,Hello£¡
  I want to implement the style support for svg through the way jpeg
and png did. I'm gonna pass the SVGGraphics2D class (provided by
batik)
to the paint method of the renderer(as the first parameter, graphic).
I
think in this way the svg will be painted the same as jpeg and png.
Can i succeed?
Thanks a lot.
======= 2004-09-29 01:06:44 You wrote£º=======
>No, it's not you. Style support is not yet available for SVG. We
hope
>to improve this in the future. The contributor who wrote the code
just
>did style transformations on the client side. So it will return the
>features, but if you want them to look good you need to do it
yourself.
>Chris
>> Hello,
>> I'm using GeoServer and i've meet a problem.
>> It seems that the result of wms queries with
"Format=image/svg+xml"
>> is not the same
>> as jpeg or png. The svg result is colorless, and the shapes are
also
>> different. Is it my fault or a bug or GeoServer just doesn't
>> implement it?
>> Thanks a lot
>> This SF.Net email is sponsored by: YOU BE THE JUDGE. Be one of 170
>> Project Admins to receive an Apple iPod Mini FREE for your
judgement
>> on
>> who ports your project to Linux PPC the best. Sponsored by IBM.
>> Deadline: Sept. 24. Go here: http://sf.net/ppc_contest.php
>> _______________________________________________
>> Geoserver-devel mailing list
>> Geoserver-devel@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
>This mail sent through IMP: https://webmail.limegroup.com/
      Yours Sincerely,
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡²Ì´í
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡stripper@anonymised.com
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡2004-09-30
