working on the scalability of the UI along with JDBCConfig with stumbled into
a few issues in the preview tables, which require some changes in JDBCConfig
and GeoServer alike to work efficiently.
The cached layers preview basically does a scan along all layers to find the cached
ones, matching them against the GWC own tiled cached layers (which are a parallel
set of layers, not kept in the DB).
To avoid this, we’d like to propose adding in each layer metadata map a “tileCached”
property, and then expose this new nested property as one that JDBCConfig can
filter against, I guess it would look like “metadata.tileCached” syntax wise.
Managing this property might be tricky, as far as I can see it would have to be done
in the UI itself.
And we’d need to find a way to populate it for all layers that are missing it, on startup,
have some class that looks for all layers not having this property, and would populate it.
Just to be sure, with the integrated GWC there is no way to manipulate the caching properties
of a layer via REST?
The global layer preview requires to treat layers and layer groups and a single entity,
that can be filtered, sorted and paged upon.
At the catalog level we have PublishedInfo, which is not managed by JDBCConfig today,
but I guess nothing prevents adding it, right?
Here again we have to deal with a notion of a layer being “visible”, that is enabled
and advertised, and a layer group being “deeply enabled”, that is, make sure that
every nested layer in the group is enabled (eventually deeply nested, layer groups
can contain other layer groups).
In this case I’d suggest to add in the metadata map of the layer groups a derived
property called visible, that specific CatalogListener will maintain over time,
and have this be one of the properties that JDBCConfig can filter against.
The above works assuming JDBCConfig manages inheritance hierarchies of sorts,
which I thought it did since I see is has property types for both resourceinfo,
featuretypeinfo and coverageinfo, but looking at imported data, it seems that
nothing was filled in the resourceinfo property set??
Could anybody point at the code that manages this, if it does at all?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
