[Geoserver-devel] Hold on! stuff being moving around
As per today's IRC meeting, geoserver development has to be held until we move
some stuff around.
If you have something to commit do it now. I will wait for Justin to come back
online, wich should happen on the next hour or two, and then will perform the
following changes:
- 1.5.x branch will be called ows4
- trunk will be copied to 1.4.x branch
- trunk will become 1.5.x
After that, all 1.4.x development shall be done on its branch, and trunk will
be open for WCS merge.
I'll send another message just before doing the move.
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
Alright, I am out of the pool, go ahead and do the move.
-Justin
Gabriel Roldán wrote:
some stuff around.
following changes:
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hi again,
in the next couple minutes I'll be actually doing the move.
Will post again when it's done.
Gabriel.
On Tuesday 17 October 2006 22:30, Gabriel Roldán wrote:
move some stuff around.
back online, wich should happen on the next hour or two, and then will
perform the following changes:
will be open for WCS merge.
I have finished the branch organization. The result is:
- 1.4.x stable branch (was trunk)
- trunk marked as 1.5.x
- old 1.5.x renamed ows4
Thanks to all for waiting till this changes took place.
Gabriel
On Tuesday 17 October 2006 23:53, Gabriel Roldán wrote:
Hi again,
Gabriel.
> Hi all,
> Regards,
Thanks for doing this Gabriel!
Brent Owens
(The Open Planning Project)
Gabriel
Hi again,
Gabriel.
Will the 1.4.x_merge_wcs branch now take its cool WCS-ness over to the trunk? (to be available when 1.5.x is released)
I.e., if I want a working WCS branch, should I use 1.4.x_merge_wcs, or should I use trunk?
Somehow I'm guessing the answer is "right now use 1.4.x_merge_wcs, but slowly you'll want to start using trunk"
--saul
should I use trunk?
You got it :slight_smile: Btw, I would say "very soon" instead of "slowly". Alessio and
Simone could give you a better schedule, but it seems they plan to merge
asap.
Gabriel
--saul
WCS will be merging onto trunk shortly, but right now trunk is just what trunk was (1.4) but with the pom version numbers now reading 1.5.
Alessio will let us all know when he will be merging WCS to trunk so we know where to develop.
Brent Owens
--saul
Today I will finish the porting of merge_wcs on trunk. I will send a mail as soon the port is done!
Brent Owens
should I use trunk?
Somehow I’m guessing the answer is “right now use 1.4.x_merge_wcs, but
slowly you’ll want to start using trunk”
–saul
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Hi guys,
to use as few words as possible:
coooool!
Simone.
> Brent Owens
> > should I use trunk?
> > --saul
easier
easier
Eng. Simone Giannecchini
President /CEO GeoSolutions
