[Geoserver-devel] Hosting proposals
With the unreliability of our confluence instance my plan is rather than keep it up for hosting proposals I am instead going to do an export from confluence as static html and host that for now. The confluence install will still be around if we need it though, for instance if we want to grab the raw content markup.
That leaves the question about what to do moving forward. For the time being can we use the github wiki if someone needs to write a proposal?
As for what to do long term not sure how to proceed, I guess let’s enumerate the options and put it to a vote. The options as I see them are:
  1. Use the Github Wiki
  2. Setup confluence hosted at CodeHaus
Any others out there?
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Can you put the HTML export somewhere?
  1. Separate repo, published using github wiki heckles (to allow for pull requests)
Jody Garnett
On Thu, May 15, 2014 at 6:46 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-devel mailing list
On Thu, May 15, 2014 at 8:40 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Yes, this what I meant. They will be hosted somewhere at a stable url.
3. Separate repo, published using github wiki heckles (to allow for pull
requests)
Jody Garnett
As for what to do long term not sure how to proceed, I guess let's
*Justin Deoliveira*
@j_deolive <https://twitter.com/j_deolive&gt;
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
available
Simple to use. Nothing to install. Get started now for free."
*Justin Deoliveira*
Sorry I was king for a zip we an look at converting.
On Thu, May 15, 2014 at 8:40 AM, Jody Garnett jody.garnett@anonymised.com wrote:
Justin Deoliveira
@j_deolive
Jody Garnett
On Thu, May 15, 2014 at 6:46 AM, Justin Deoliveira <jdeolive@…3839…> wrote:
Justin Deoliveira
@j_deolive
Geoserver-devel@anonymised.comnet
Do you want the xml zip? I don’t imagine the html or pdf version will be that useful?
Anyways, for now all the old confluence content is available at http://old.geoserver.org.
On Thu, May 15, 2014 at 10:30 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
On Thursday, May 15, 2014, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Jody Garnett
Justin Deoliveira
@j_deolive
Justin Deoliveira
@j_deolive
Jody Garnett
On Thu, May 15, 2014 at 6:46 AM, Justin Deoliveira jdeolive@anonymised.com wrote:
Justin Deoliveira
@j_deolive
