[Geoserver-devel] how a wms request is handled by geoserver
Dear Geoserver Developers
I am very new to GeoServer development. I am using geoserver 2.10 in NetBeans. I wanted to know that when the geoserver is up and running, what is the exact sequence of operations for handling getmap operation request of WMS i.e. methods of which classes are called and in what sequence. It would be very helpful if anybody can tell from which operation of a class it starts. If some documentation is available or some help is available regarding it, kindly share a link with me. Thanking you in advance.
regards
Chandra Mohan Sharma
Hi Chandra,
there is no documentation about that, but you can start a debug session and put breakpoints in these files/lines, that should give
you enough to figure it out by yourself:
https://github.com/geoserver/geoserver/blob/master/src/ows/src/main/java/org/geoserver/ows/Dispatcher.java#L238
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/map/GetMapKvpRequestReader.java#L193
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/DefaultWebMapService.java#L316
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/GetMap.java#L119
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapOutputFormat.java#L280
Regards
On Wed, Dec 28, 2016 at 8:40 AM, Chandra Mohan Sharma <chandramohansharma.cms@anonymised.com> wrote:
regards
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
