[Geoserver-devel] How about having all JIRA discussions getting on the devel list too?
I see in other projects that whatever change happens to JIRA tickets, it gets notified
on the developer list as well.
Given we have a sizable amount of discussion going on in JIRA that is lost to developer eyes,
what would you think about having new comments on each ticket
also be sent to the developer list?
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hmm, not sure if this is an optimal solution for part time developers like me. Its already a daily effort to filter the mails related to me. Too many mails in the inbox may result in discarding mails without reading them.
Is it possible to give the right to add watchers for an issue to each developer ?. I can remember you often added me as a watcher. I think this could be a solution for a more fine grained mail distribution.
Christian
On Sat, Feb 15, 2014 at 3:03 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
Depending on what mail client you use, you should be able to set up some sort of filters. This would allow you to automatically divide out the JIRA updates and either put them into a new folder or bin them as desired. I use it to divide all my mailing list stuff into appropriate folders and it’s exceptionally useful. (It’s also useful for automatically binning institutional spam within your organisation :wink: ).
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 16 February 2014 10:22, Christian Mueller <christian.mueller@anonymised.com> wrote:
Christian
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jonathan
I am using GMail and use tags to divide the different mailing lists. (Gmail uses tags instead of folders allowing assignment of multiple tags to a mail).
Nevertheless I have to inspect each incoming mail.
Christian
On Mon, Feb 17, 2014 at 12:17 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Christian,
Jonathan
Christian
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Christian,
I’m using Gmail too and am also using tags. What you want is to use filters.
Take a gander at this page:
https://support.google.com/mail/answer/6579?hl=en
I’m on ~13+ mailing lists and the 9 busiest all get filtered with a separate tag - the rest just go into the “Mailing lists” parent tag. Then I can browse them at my leisure (i.e. the MapServer list I rarely bother reading, GeoServer ones I read frequently).
It’s simply a matter of figuring out what the unique element of an email is (gmail does a good job of picking this up though). It’s extremely powerful and saves having to manually do it; sounds like it’ll save you a bunch of time.
Best,
Jonathan
On 17 February 2014 12:21, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Jonathan
Christian
Hi Christian,
Jonathan
Christian
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Feb 17, 2014 at 2:13 PM, Jonathan Moules <
Hi Christian,
I'm using Gmail too and am also using tags. What you want is to use
filters.
I'm on ~13+ mailing lists and the 9 busiest all get filtered with a
separate tag - the rest just go into the "Mailing lists" parent tag. Then I
It's simply a matter of figuring out what the unique element of an email
is (gmail does a good job of picking this up though). It's extremely
powerful and saves having to manually do it; sounds like it'll save you a
bunch of time.
More ontopic: I quite like Andrea's notion. One thing to consider - QGIS I
think has tickets go to a separate list, maybe that would be worth
considering depending on how often updates happen on the JIRA tickets.
Yes, that would also be a nice option. So that people can opt-in if they
are interested, and we could just leave the ticket creation messages on
gs-devel...
or maybe just move everything there
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
