[Geoserver-devel] How can I retrieve a set of properties of the features in a DWithin filter
I'm trying to retrieve only the property 'name' of the features within a
distance of 10 meters from the specified point.
What should it be the query?
Because this is getting an exception from CartesianDistanceFilter:
<Query TypeName="ejes">
    <PropertyName>name</PropertyName>
    <Filter>
        <DWithin>
            <PropertyName>the_geom</PropertyName>
            <Geometry gml:Point>44000,470000</Geometry>
            <Distance
unit="http://www.uomdict.com/uom.html#meters&quot;&gt;10&lt;/Distance&gt;
        </DWithin>
    </Filter>
</Query>
If I omit the '<PropertyName>name</PropertyName>', it retrieves all the
properties of all the features within that area.
Any help?
Thanks in advance.
---Publicidad--------------------------------------------------------
Juega con Ventura24.es, lotería inteligente y multiplica tus
posibilidades!! http://www.iespana.es/_reloc/email.ventura
Next time include at least the exception that you get, but I think I have
an idea what's going on. I've never actually seen that form of gml
<Geometry gml:Point>44000,47000<Geometry>
I would use something like
<gml:Point><gml:coordinates>44000,47000</gml:coordinates</gml:Point>
So try the query out with that. If the Geometry gml:Point style is valid
gml then I'll look into supporting it... But for now I'd just use the
more traditionaly gml:coordinates style. Also, be sure that you declare
the gml prefix namespace. The full FeatureRequest is not there for me to
see, but if you don't have an xs:gml="http://www.opengis.net/gml&quot; then
that can also be a source of errors. Hope this helps, if it's not then
send along the actual exception and set configuration.xml logging level to
FINEST and send catalina.out.
     thanks,
  Chris
    <Filter>
        <DWithin>
            <Distance
        </DWithin>
    </Filter>
</Query>
Any help?
Thanks in advance.
This SF.net email is sponsored by: SF.net Giveback Program.
Does SourceForge.net help you be more productive? Does it
help you create better code? SHARE THE LOVE, and help us help
YOU! Click Here: http://sourceforge.net/donate/
Geoserver-devel mailing list
