[Geoserver-devel] How do you upload a Shapefile using cURL and REST?
Can someone please tell me how to upload a Shapefile using cURL and the REST
plugin? I've tried the few examples on the GeoServer site, but nothing
seems to work... Once I do upload a Shapefile to GeoServer, in which
directory should the file be?
Sam
View this message in context: http://www.nabble.com/How-do-you-upload-a-Shapefile-using-cURL-and-REST--tp23808087p23808087.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hi Sam,
This is documented here:
http://docs.geoserver.org/1.7.x/user/extensions/rest/rest-config-examples-curl.html#uploading-a-shapefile
After you upload the file it will be located in:
  <GEOSERVER_DATA_DIRECTORY>/data/<dataStoreName>
-Justin
samclemmens wrote:
Sam
Justin Deoliveira
OpenGeo - http://opengeo.org
hello justin, I have a problem when I try to upload a geotiff for example
with rest, in a java class(I don't use curl)
Everything is working fine except that my file.geotiff is not copied in the
geoserver_data_dri/coverageName/ but directly in geoserver_data_dir. I tried
out to see in the rest api code but I don t find anything on this subject.
Could you help me ?
samclemmens wrote:
REST plugin? I've tried the few examples on the GeoServer site, but
nothing seems to work... Once I do upload a Shapefile to GeoServer, in
which directory should the file be?
Sam
View this message in context: http://www.nabble.com/How-do-you-upload-a-Shapefile-using-cURL-and-REST--tp23808087p25906980.html
Usually the file should be copied into <GEOSERVER_DATA_DIR>/data/<coverageStoreName>
How are you running GeoServer? And how is the GEOSERVER_DATA_DIR set? Are you running standalone jetty or with tomcat? The way the data dir gets set in a servlet container is a bit different and thinking about it it could lead to files being copied to different places.
The place in the code where this is handled is in the StoreFileResource#handleFileUpload() method.
http://svn.codehaus.org/geoserver/trunk/src/extension/restconfig/src/main/java/org/geoserver/catalog/rest/StoreFileResource.java
-Justin
Could you help me ?
samclemmens wrote:
Sam
Justin Deoliveira
