Hello everyone,
I would like to know if it is possible to build a minimal GeoServer (war
archive with Maven (I am a beginner with Maven)) from GeoServer source ?
A minimal GeoServer will be a GeoServer without the admin user interface in
jsp (we don't need it).
I trie "mvn -DconfigId=minimal clean install" to have a small data folder.
Thanks for your help
Robin
View this message in context: http://www.nabble.com/How-to-build-minimal-GeoServer---tp23499832p23499832.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hi Robin,
Building a geoserver without the admin interface is kind of tough. The reason being that the web application and all the dependencies on the other components are built into a single "web" module.
With 2.0 however, it is more likely possible because we have separated out the web application into a separate module. However I have never tried it so not sure.
You could build a geoserver war, deploy it, and then remove the web application module to see if it runs.
-Justin
Spirifer wrote:
Hello everyone,
Robin
Justin Deoliveira
OpenGeo - http://opengeo.org
