[Geoserver-devel] How to delete pyramid files after removing a coveragestore ?
Hi !
I currently get this problem : I insert a pyramid (tiff files) in my geoserver and visualize it on my client.
Then, i remove the layers and the coveragestore and try to remove all the pyramid files BUT some files are locked by Geoserver and can not be removed !
All the operations are done using the rest api and the files deletion is managed by the java method file.close(), applied on each pyramid’s file (trying to use the windows explorer does the same thing).
I can’t understand why Geoserver does not close the files streams after using them…
I tried to import my pyramid in geoserver, create a layer, and then remove everything without visualize the layer in my client… Doing that, everything is working fine…
The only way I have to remove the files is to restart Tomcat and I can not do that in a production environment !
So… If somebody gets an idea on how to solve this problem, it would be great !
Thanks !
Thomas
Hotmail débarque sur votre téléphone ! Paramétrez Hotmail sur votre téléphone! Gratuit !
