I’m studying how to implement “search” function based on Gerserver. But I
suffered server problems as follow. Before I posted my questions, I had
searched the forum without helpful responds.
1. The Syntax of CQL. Though there is a guideline about CQL on the website,
it doesn’t provide enough in my views. My questions: how to filter by a
street name (a string, like “E 66th St”)? In the tiger-ny map, the CQL
filer: tiger_roads.NAME "is" E 66th St, but it is wrong.
2. I just want to develop “map search” like Google map, MS Live map, as my
further study platform. Unluckily, I don’t know how to start the work. Could
you give some cues or steps? Of course, if there are some examples, it
should be better.
The CQL thing has an offical specification (part of the catalog 2.0
specification from OGC). However this format is very limited - you can
using he "like" filter to perform some basic wildcard searches.
Your bigger question of how to google like searches is of course a bit
larger then CQL.
In udig table view we provide a "full text search"; but we do that by
going through features in memory and doing just that - full text
search. If the user tells us a specific attribute to search (from a
drop down list) we can use the like filter and go faster; or if they
give us a CQL expression (in the same drop down list) we can go
faster.
Other then that you may want to deploy a search engine (GeoNetwork
uses one for search metadata) and reference each feature id from each
block of text.
Jody
On Tue, May 12, 2009 at 6:20 AM, Vincent2009
<limin.zeng@anonymised.com> wrote:
Hi ALL,
should be better.
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Thank you.
I will check the specification of CQL. And Mr. Gabriel Roldan responded
helpful documents to set up a web
map app step by step,
(http://docs.codehaus.org/display/MAP/Building+A+Web+App ). It is indeed a
good
introduction to teach how to develop a search function with MapBuild and
Geoserver. Thanks.
Jody Garnett-3 wrote:
Hi Vincent:
larger then CQL.
faster.
block of text.
Jody
Hi ALL,
website,
as my
Could
should be better.
to
i700
i700
