Hi list,
Im trying to retrieve a geometry as KML file through my custom servlet, what libraries/class/functions do i require to get a KML response? my servlet is not working through wfs
regards,
Imran
I.R
Hi list,
regards,
Imran
I.R
There are a number of classes in the wms module for generating kml:
There coupled tightly to the WMS chain but could probably be reused.
-Justin
Imran Rajjad wrote:
Hi list,
regards,
Imran--
I.R------------------------------------------------------------------------
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july------------------------------------------------------------------------
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
doesnt wms service responds with an image file,actualy i want to respond with a kml file that can be saved on disk and later opened in Google Earth!
I`l take a look at the link, thanx a lot
regards,
Imran
On Wed, Nov 18, 2009 at 6:21 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
Imran Rajjad wrote:
Hi list,
regards,
Imran–
I.R
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what’s new with
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Justin Deoliveira
I.R
Hi Irman,
Actually no the wms spec does not bind one to returning an image. The spec has the notion of "output formats". An output format can return non image content types such as svg, kml, rss, etc...
And this indeed is what geoserver uses to return KML. Take a regular WMS request for a png image and change the output format to "kml" and you will get kml back.
http://docs.geoserver.org/2.0.x/en/user/googleearth/index.html
-Justin
Imran Rajjad wrote:
regards,
ImranOn Wed, Nov 18, 2009 at 6:21 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
-Justin
Imran Rajjad wrote:
Hi list,
KML response? my servlet is not working through wfsregards,
Imran-- I.R
<mailto:Geoserver-devel@lists.sourceforge.net>
https://lists.sourceforge.net/lists/listinfo/geoserver-devel-- Justin Deoliveira
Enterprise support for open source geospatial.--
I.R
Justin Deoliveira
