[Geoserver-devel] how to handle contributions (here pull requests)
Hello everybody,
I just reviewed some pull requests and I’m a bit unsure how to handle these.
Is there a doc/description out there how to handle contributions (here pull requests) created by others. Does the committer has to sign a CLA or is it possible to accept requests with a few (e.g. up to 1000) line changes. How we can find out who did the paperwork already and is a List ofContributors published somewhere?
Thanks a lot
  • Frank
Seems that I found what I was looking for : https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
  • Frank
2015-09-08 22:59 GMT+02:00 Frank Gasdorf <fgdrf@anonymised.com>:
Hello everybody,
Thanks a lot
  • Frank
Did you find out how to access the list of signed agreements? I am not sure it is public. Andrea (project officer), any ideas?
of Contributors published somewhere?
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Ben, not yet :wink: But I created a pull to update (C)CLA links to OSGeo wiki pages. Seems GeoTools needs an update as well.
  • Frank
2015-09-08 23:17 GMT+02:00 Ben Caradoc-Davies <ben@anonymised.com>:
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Found a hint that there should be a dropbox or shared folder where the recieved aggreements are copied to
Sadly the final links is missing …
  • Frank
2015-09-08 23:25 GMT+02:00 Frank Gasdorf <fgdrf@anonymised.com>:
  • Frank
Director
New Zealand
See https://trac.osgeo.org/osgeo/ticket/1338
On Tue, Sep 8, 2015 at 11:17 PM, Ben Caradoc-Davies <ben@anonymised.com>
Jody is right, they are available only to those who can access that svn
repository...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Tue, Sep 8, 2015 at 11:13 PM, Frank Gasdorf <fgdrf@anonymised.com>
Well... yes, it's a starting point. The reviewer should also check if the
pull request is improvement proposal
worthy (large change, or is it changing core public API), and in case of
public API, if the change "makes sense"
among the rest of the existing code (many ways of getting the same result,
some are pretty ugly though),
if it looks or not that it's introducing bugs and regressions, and so on.
A first pass from anybody looking at the easily verifiable bits is
certainly going to help a lot, many
pull requests are failing on the basics, a second check by someone that has
experience
on the module(s) being touched in question is normally a good idea for non
trivial changes.
Ing. Andrea Aime
@geowolf
Technical Lead
n Tue, Sep 8, 2015 at 10:59 PM, Frank Gasdorf <fgdrf@anonymised.com>
wrote:
Hello everybody,
I just reviewed some pull requests and I'm a bit unsure how to handle
these.
changes.
The I believe unwritten agreement was that a patch touching at most one
file was ok to go without a contributor
agreement. That of course does not count the mandatory test, otherwise
there would be no pull request
that we can accept (since we accept basically none without a test)
Ing. Andrea Aime
@geowolf
Technical Lead
If you're looking for mine, they are 97 and 98.
Brad
