[Geoserver-devel] How to modify getmap
I just download and import Geoserver source code to Eclipse. I need to modify getMap so that after read the GIS data from DB this function move all Coordinates.
For example, all Coordinates are moved to north 20 meters.
How to modify this function at Geoserver?
Thanks
You may consider changing things on the other end; ie request 20 meters south :slight_smile:
Why the distance of 20 mins? Is your data wrong; or are you trying to combine two data sets and they are not lining up?
Jody
Thanks
Nokia and AT&T present the 2010 Calling All Innovators-North America contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev_______________________________________________
Geoserver-devel mailing list
Geoserver-devel@anonymised.coms.sourceforge.net
Hi ,
Thanks for your reply. I need to offset the map because most programmers will not on client site. The client does not want to provide correct data outside their office. Originally, they use ArcGIS. But this time my boss wants to change Geoserver.
request 20 meters: do you mean after publishing the map , the java or web application requests the corrent map and plus 20 meters distance?
Subject: Re: [Geoserver-devel] How to modify getmap
Date: Sat, 23 Oct 2010 14:03:22 +1000
CC: geoserver-devel@lists.sourceforge.net
To: lv.123@anonymised.com
Jody
Thanks
If all you need is styling with 20m offset (instead of providing
corrected data) using geometry transformations in your SLD might be all
you need:
<http://blog.geoserver.org/2010/03/17/extending-your-map-styling-with-geometry-transformations/&gt;
Gabriel
On Mon, 2010-10-25 at 02:34 +0000, lv wrote:
Hi ,
______________________________________________________________________
Jody
        Thanks
        America contest
         U.S. and Canada
        $6M in marketing
        Ovi Store
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
