[Geoserver-devel] How to rebuild Geoserver source code to WAR file.
I changed some java file of GeoTools and using maven to build it (mvn clean install ¨CDskipTests).
Which library of Geoserver should be replaced and how to rebuild Geoserver source code to a new WAR file?
If you build geoserver from the root, or just build the web module under web/app target you will see a geoserver.war file.
Just a note. If you are making changes in geotools and trying to get geoserver to pick them up use the “-o” (offline) flag or else it is possible that maven will download a newer copy of the geotools jar you changed.
-Justin
2010/11/9 lv <lv.123@anonymised.com.>
I changed some java file of GeoTools and using maven to build it (mvn clean install –DskipTests).
The Next 800 Companies to Lead America’s Growth: New Video Whitepaper
David G. Thomson, author of the best-selling book “Blueprint to a
Billion” shares his insights and actions to help propel your
business during the next growth cycle. Listen Now!
http://p.sf.net/sfu/SAP-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
