[Geoserver-devel] How to reopen issue 6568
I ran into issue 6568 while uploading SLDs with the Geoserver REST API. I noticed Jody closed it with a 'should ... correctly' however it doesn't. I've tested it with the kartoza docker with geoserver 2.12 and both with the SLD from the issue and a my own test SLD.
So my question is, how do I reopen an issue in Atlassian?
I've added a bit more info and am happy to follow up, link: https://osgeo-org.atlassian.net/browse/GEOS-6568
Steven
Hi Steven,
as written on the ticket, please try a 2.14.2 (or even a 2.15-RC), more fixes have been made later in that area.
Both 2.12 and 2.13 are dead, you should check out a supported version before reporting/reopening a ticket.
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
Thanks, I noticed the comment just after I sent the email. I’m trying to get a 2.14.2 version working and will test with 2.15RC if 2.14 also doesn’t work.
Steven
On 19-02-19 12:17, Andrea Aime wrote:
Hi Steven,
On Tue, Feb 19, 2019 at 12:00 PM Steven Ottens <steven@anonymised.com> wrote:
I noticed Jody closed it with a ‘should … correctly’ however it
doesn’t. I’ve tested it with the kartoza docker with geoserver 2.12 and
I’ve added a bit more info and am happy to follow up, link:
Steven
Geoserver-devel mailing list
