[Geoserver-devel] How to run CITE tests with Oracle DataStore?
    I am interested to run CITE tests on GeoServer with Oracle as the DataStore. If anybody has previously done this can you help me in setting up the database and configuration files.
Also I am interested to run ACE-GIS tests, but I cant run GeoServer on public IP.
Is there any place where I can get the sources of these tests, so that I can run them locally.
Thanks & regards,
Subrahmanyam.
_________________________________________________________________
Sell your old furniture. http://ads2.baazee.com/cgi-bin/banners/redirect.pl?id=1124 Electronics,books or even your car.
Sorry for the late response, I~ve been on the road.
CITE with oracle and geoserver has not been done. And due to case
sensitivity it wont work right away, as the CITE tests are very strict
about the format of the data. Fixing may be as simple as changing the
oracel data store in geotools to use and return lower cases. FOr 1.3 we
are planning being able to map different names to database columns, which
should make the cite tests much easier to pass.
As for the ACE-GIS tests, I will send you the code (and can send it to
anyone else who might like it).
best regards,
Chris
On Mon, 1 Nov 2004, Subrahmanyam vinjamuri wrote:
public IP.
run them locally.
Thanks & regards,
Subrahmanyam.
or even your car.
This SF.Net email is sponsored by:
Sybase ASE Linux Express Edition - download now for FREE
LinuxWorld Reader's Choice Award Winner for best database on Linux.
http://ads.osdn.com/?ad_id=5588&alloc_id=12065&op=click
Geoserver-devel mailing list
