I am sorry if this is a duplicate request. I sent a similar request to
Geoserver-User for a couple of weeks and have not received any answer. I am
not sure if Geoserver-User is the wrong group for this kind of request so I
re-send this request to your group. Basically, I need to know how to write
Geoserver data store extension for raster data. I have been googling about
this topic with no luck. Please let me know if you need more details. Any
help on this is greatly appreciated.
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now. http://p.sf.net/sfu/bds
Thanks for your reply. I already know how the write plugin for raster by looking at how it was done in GeoTools. However, I still have some problem to fix. The map image returned from my code does not align correctly. I believe it has to do with some grid to world transformation that I have not been able to figure out due to lack of understanding of Geoserver/GeoTools code.
Okay, you best ask on the geotools-devel list then, and I recommend picking up and reproducing test cases from the other raster modules in order to learn more.
