What happens after I press Save in the Transifex UI? How and when can I test how my translations appear in the UI of Geoserver? How can I select the language – I am sure that even if we had Finnish translation ready I would like to run Geoserver with English UI on my computer which has Finnish locale settings. I have translated OpenJUMP in Finnish and I know that I can start it in other languages by editing the Java options in the startup script
set JAVA_OPTS=%JAVA_OPTS% -Duser.language=de -Duser.country=DE
Is it possible to do the same with Geoserver?
-Jukka Rahkonen-
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now! http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
In the past we had kind of “on request” process to get translations back into codebase. Normally teams are working hard in a pre-release timeslot. Few of them managed to get it back into codebase by itself using the transifex client tool or just downloading properties files and created pull requests for github out of it.
Automation ist only etablished from github to transifex to get latest key’s and changes from values as a base into transifex. Teams are getting notifications (if enabled) about changes.
Jukka you are right, you can set defaults for the UI using properties user.language and user.country [1] but at the end t dependes from from Browser settings. Change the language for your prefered Browser and try GeoServer UI again (maybe after restart of your Browser)
We have filed an improvement ticket to provide UI-Elements for users to change Locale at runtime [2]. It would help to change language independenly from Browser settings (Good example is on Transifex itself)
