Le Vendredi 25 Novembre 2005 20:53, simone giannecchini a écrit :
Hi Simone,
As I am not sure my saturday's mail hit the list, I'm sending it again with
some new informations :
1) in the context file of tomcat (corrected from my initial mail) :
<Context docBase="/var/www/webapps/geoserver-1.3.0"
path="/geoserver-v1.3.0"
reloadable="true">
<Resource name="jdbc/EPSG" auth="Container"
type="javax.sql.DataSource"
username="Geotools" password="Geotools"
driverClassName="org.postgresql.Driver"
url="jdbc:postgresql://127.0.0.1:5432/EPSG"
maxActive="8"
maxIdle="4"
maxWait="-1"/>
</Context>
2) It is then mandatory to have jdbcPostgres.jar in $CATALINA_HOME/common/lib
otherwise Tomcat does't find the driver. This leads to have that jar both in
$CATALINA_HOME/common/lib and in ~geoserver/WEB-INF/lib
3) in the ~geoserver/WEB-INF/web.xml (corrected from my initial mail) :
<description>
EPSG database for spatial reference systems
</description>
<res-ref-name>
jdbc/EPSG
</res-ref-name>
<res-type>
</res-type>
<res-auth>
Container
</res-auth>
</resource-ref>
4) the following code finds the EPSG database :
InitialContext initCtx= new InitialContext();
DataSource ds= (DataSource)initCtx.lookup("java:comp/env/jdbc/EPSG");
I don't know whether gt2 uses such a mecanism for retrieving named resources
as you mentionned in 1) of your mail ?
It seems that Tomcat retrieves the javax.sql.DataSource without problem (point
2 of your mail)
5) I had to fix, for postgresql, a NullException in the PostgreDataSource.java
(I sent you that file on saturday with CC to Martin Desruisseaux)
6) using svn geotools instead of the gt2 released with svn geoserver, I still
get the same error :
java.lang.AbstractMethodError:
org.geotools.referencing.factory.epsg.PostgreDataSource.createFactory(Lorg/geotools/referencing/factory/FactoryGroup;)Lorg/geotools/referencing/factory/AbstractAuthorityFactory;
at
org.geotools.referencing.factory.epsg.DefaultFactory.createFactory(DefaultFactory.java:250)
at
org.geotools.referencing.factory.epsg.DefaultFactory.createBackingStore(DefaultFactory.java:308)
at
org.geotools.referencing.factory.DeferredAuthorityFactory.getBackingStore(DeferredAuthorityFactory.java:127)
at
org.geotools.referencing.factory.BufferedAuthorityFactory.isReady(BufferedAuthorityFactory.java:194)
at
org.geotools.referencing.factory.DeferredAuthorityFactory.isReady(DeferredAuthorityFactory.java:115)
at
org.geotools.factory.FactoryRegistry$1.filter(FactoryRegistry.java:81)
at javax.imageio.spi.FilterIterator.advance(ServiceRegistry.java:793)
at javax.imageio.spi.FilterIterator.<init>(ServiceRegistry.java:787)
at
javax.imageio.spi.ServiceRegistry.getServiceProviders(ServiceRegistry.java:491)
at
org.geotools.factory.FactoryRegistry.getServiceProviders(FactoryRegistry.java:106)
at
org.geotools.referencing.FactoryFinder.getCRSAuthorityFactories(FactoryFinder.java:315)
at org.geotools.referencing.CRS.decode(CRS.java:217)
at
org.geotools.data.postgis.referencing.PostgisAuthorityFactory.createFromAuthority(PostgisAuthorityFactory.java:103)
at
org.geotools.data.postgis.referencing.PostgisAuthorityFactory.createCRS(PostgisAuthorityFactory.java:60)
at
org.geotools.data.postgis.PostgisDataStore.getGeometryAttribute(PostgisDataStore.java:947)
at
org.geotools.data.postgis.PostgisDataStore.buildAttributeType(PostgisDataStore.java:878)
at
org.geotools.data.jdbc.JDBC1DataStore.buildSchema(JDBC1DataStore.java:1150)
at
org.geotools.data.postgis.PostgisDataStore.buildSchema(PostgisDataStore.java:593)
at
org.geotools.data.jdbc.FeatureTypeHandler.getFeatureTypeInfo(FeatureTypeHandler.java:200)
at
org.geotools.data.jdbc.FeatureTypeHandler.getSchema(FeatureTypeHandler.java:168)
at
org.geotools.data.jdbc.JDBC1DataStore.getSchema(JDBC1DataStore.java:388)
at org.vfny.geoserver.global.Data.loadFeatureTypes(Data.java:345)
at org.vfny.geoserver.global.Data.load(Data.java:154)
at
org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:109)
at
org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:1158)
at org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
I am not sure the API are compatible ...
7) Suggestion: it would be great to have epsg-hsql.jar, epsg-postgresql.jar
along with epsg-wkt.jar and other gt2 jars. Using build.properties, one could
add a "prefered.epsg.jar" property that points to the epsg-*.jar to be put in
the war. Having epsg-*.jar would solve 6)
8) Once it works, I will put all these on the GEOSDOC wiki as Chris suggested.
Hi Didier,
thanks for the hint, I think on monday (maybe tuesday...) I will
compare this with the one I wrote for HSQL since I do not have my code
here, but I am still afraid that this won't help since this is exactly
the way I would do this ( I would still like to remark that I am not a
J2EE expert) and I am not surprised that it works for postgresql.
If you look at the HSQL implementations of an EPSG autorithy factory
in GeoTols, things are a bit different.
Anyway an easy solution would be switch from HSQL to postgresql!!! I
think I will get back to you next in order to perform this switch, but
before I would like to dig a bit more in this issue with HSQL.
Thanks a lot
Simone.
On 11/25/05, Richard didier <dgr@anonymised.com> wrote:
> Le Vendredi 25 Novembre 2005 15:23, simone giannecchini a écrit :
> > ---------- Forwarded message ----------
> > From: simone giannecchini <simboss1@anonymised.com>
> > Date: Nov 25, 2005 3:14 PM
> > Subject: HSQL and JNDI
> > To: "geotools-devel@lists.sourceforge.net", Martin Desruisseaux
> > <martin.desruisseaux@anonymised.com>
> > Hi list, hi Martin,
> Hi Simone,
> I didn't have checked if this is working completely but here is the
> tomcat
> (5.5 with Java 1.5 under Linux) setup I have for epsg-postgresql :
> > in the last weeks I have been working mainly on the geoserver WCS and
> > on the coverage branch. I have run into an annoying issue which maybe
> > you could help me to sort out.
> > I noticed that the epsg-hqsl plugin which relies on the hsql embedded
> > db tries to retrieve a DataSource from JNDI incase such a data source
> > has been registered.
> > I am not a J2EE expert but I have been trying to register such a data
> > source using tomcat JNDI emulation without success.
> > Problems in my opinion are:
> > 1>Tomcat JNDI emulation puts resource under the java:comp/env context
> > and there is no wy can change that. At the same time the default
> > factory looks for a data source under the initial context without the
> > above mentioned name qualification. I am afraid that this won't ever
> > work on tomcat.
> in the context file of tomcat :
> reloadable="true">
> <Resource name="jdbc/Geotools" auth="Container"
> maxActive="8"
> maxIdle="4"
> maxWait="-1"/>
> </Context>
> > 2>The data source we are expecting to find in the JNDI is a sub
> > interface of javax.sql.DataSource but due to the connection pooling
> > mechanism that runs behind Tomcat we will never be able to retrieve
> > such an object.
> In the geoserverWEB-INF/web.xml :
> <resource-ref>
> <description>
> </description>
> <res-ref-name>
> jdbc/Geotools
> </res-ref-name>
> <res-type>
> </res-type>
> <res-auth>
> Container
> </res-auth>
> </resource-ref>
> </web-app>
> > I might be completely wrong I know, any input will be greatly
> > appreciated.
> This might be adequte too for hsql-epsg i guess. Any feedback would be
> great !
> > Simone.
> didier
> > This SF.net email is sponsored by: Splunk Inc. Do you grep through log
> > files for problems? Stop! Download the new AJAX search engine that
> > makes searching your log files as easy as surfing the web. DOWNLOAD
> > SPLUNK! http://ads.osdn.com/?ad_idv37&alloc_id865&op,ick
> > _______________________________________________
> > Geoserver-devel mailing list
> > Geoserver-devel@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
files for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
