Apparently I cannot release a 2.1.1 release candidate today (sorry).
For those waiting on these jars (for geoserver & udig) - I have placed the jars here:
-<http://lists.refractions.net/geotools/gt2/UDIG1.0.2>
So it seems the createRelease is extra thread unsafe? Is this a question for Amr (please fix hsql)? Or a question for the "build masters" Justin/James (please dethread createRelease)?
Jody
It managed maven build okay, but fails on createRelease...
java.sql.SQLException: The database is already in use by another process: org.hsqldb.persist.NIOLockFile@anonymised.com[file =
C:\java\geotools\gt\plugin\hsql\tempDB.lck, exists=true, locked=false, valid=false, fl =null]: java.lang.Exception: chec
kHeartbeat(): lock file [C:\java\geotools\gt\plugin\hsql\tempDB.lck] is presumably locked by another process.
at org.hsqldb.jdbc.Util.sqlException(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.<init>(Unknown Source)
at org.hsqldb.jdbcDriver.getConnection(Unknown Source)
at org.hsqldb.jdbcDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:512)
at java.sql.DriverManager.getConnection(DriverManager.java:140)
at org.geotools.data.hsql.HsqlConnectionFactory.getConnection(HsqlConnectionFactory.java:152)
at org.geotools.data.hsql.HsqlConnectionFactory.getConnection(HsqlConnectionFactory.java:123)
at org.geotools.data.hsql.HsqlConnectionFactory.getConnection(HsqlConnectionFactory.java:67)
at org.geotools.data.hsql.HsqlDataStore.createConnection(HsqlDataStore.java:397)
at org.geotools.data.hsql.HsqlDataStore.removeSchema(HsqlDataStore.java:518)
at org.geotools.data.hsql.HsqlDataStoreTest.setUp(HsqlDataStoreTest.java:102)
at junit.framework.TestCase.runBare(TestCase.java:125)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at org.apache.tools.ant.taskdefs.optional.junit.JUnitTestRunner.run(JUnitTestRunner.java:325)
at org.apache.tools.ant.taskdefs.optional.junit.JUnitTestRunner.main(JUnitTestRunner.java:536)
This same error appears multiple times.
C:\java\geotools\gt>more releaseReport-2.1.1.RC0.txt
release is 2.1.1.RC0
gt2:main OK
gt2:export-wizzard OK
gt2:property OK
gt2:shapefile OK
gt2:gml OK
gt2:dir_ds OK
gt2:graph OK
gt2:postgis OK
gt2:experiment OK
gt2:legacy OK
gt2:migrate OK
gt2:legend OK
gt2:indexed-shapefile OK
gt2:validation OK
gt2:view OK
gt2:sample-data OK
gt2:svgsupport OK
gt2:utils OK
gt2:epsg-wkt OK
gt2:image OK
gt2:arcgrid OK
gt2:arcsde OK
gt2:db2 OK
gt2:epsg-access OK
gt2:epsg-hsql OK
gt2:geomedia OK
gt2:geotiff OK
gt2:hsql OK
gt2:mysql OK
gt2:oracle-spatial OK
gt2:tiger OK
gt2:vpf OK
gt2:wms OK
gt2:wfs OK
add gt2:main jar - OK
gt2:main Libs Copied
gt2:main OK
add gt2:export-wizzard jar - OK
gt2:export-wizzard Libs Copied
add gt2:property jar - OK
gt2:property Libs Copied
gt2:property OK
add gt2:shapefile jar - OK
gt2:shapefile Libs Copied
gt2:shapefile OK
add gt2:gml jar - OK
gt2:gml Libs Copied
gt2:gml OK
add gt2:dir_ds jar - OK
gt2:dir_ds Libs Copied
gt2:dir_ds OK
add gt2:graph jar - OK
gt2:graph Libs Copied
gt2:graph OK
add gt2:postgis jar - OK
gt2:postgis Libs Copied
gt2:postgis OK
add gt2:experiment jar - OK
gt2:experiment Libs Copied
gt2:experiment OK
add gt2:legacy jar - OK
gt2:legacy Libs Copied
gt2:legacy OK
add gt2:migrate jar - OK
gt2:migrate Libs Copied
gt2:migrate OK
add gt2:legend jar - OK
gt2:legend Libs Copied
gt2:legend OK
add gt2:indexed-shapefile jar - OK
gt2:indexed-shapefile Libs Copied
add gt2:validation jar - OK
gt2:validation Libs Copied
gt2:validation OK
add gt2:view jar - OK
gt2:view Libs Copied
gt2:view OK
add gt2:sample-data jar - OK
gt2:sample-data Libs Copied
gt2:sample-data OK
add gt2:svgsupport jar - OK
gt2:svgsupport Libs Copied
gt2:svgsupport OK
add gt2:utils jar - OK
gt2:utils Libs Copied
gt2:utils OK
add gt2:epsg-wkt jar - OK
gt2:epsg-wkt Libs Copied
gt2:epsg-wkt OK
add gt2:image jar - OK
gt2:image Libs Copied
gt2:image OK
add gt2:arcgrid jar - OK
gt2:arcgrid Libs Copied
gt2:arcgrid OK
add gt2:arcsde jar - OK
gt2:arcsde Libs Copied
gt2:arcsde OK
add gt2:db2 jar - OK
gt2:db2 Libs Copied
gt2:db2 OK
add gt2:epsg-access jar - OK
gt2:epsg-access Libs Copied
gt2:epsg-access OK
add gt2:epsg-hsql jar - OK
gt2:epsg-hsql Libs Copied
gt2:epsg-hsql OK
add gt2:geomedia jar - OK
gt2:geomedia Libs Copied
gt2:geomedia OK
add gt2:geotiff jar - OK
gt2:geotiff Libs Copied
gt2:geotiff OK
add gt2:hsql jar -
