I noticed there are a few tests in the test module that will run
only if a geoserver instance is running on the same box.
Now, nobody tells which configuration of the web module should be used,
I just guessed that it's UserBasic.zip because I saw it referred in
discussion, but nowhere from the wiki (you can download it from
http://geo.openplans.org/geoserver/config/UserBasic.zip).
Now, this is bad two times:
1) no release instruction speak about these tests;
2) a unit test that needs a running server to do his job is not
the best I can think of (a way of "mocking" the server would
be much better)... moreover, if needed, the unit test
themselves should setup the server, no?
