[Geoserver-devel] Http Unit Tests
Check out:
http://docs.codehaus.org/display/GEOSDOC/InlineFeature
if you look at the attachments, you'll see an .xml file that will
produce the picture. Its based on InlineFeatures so it will work on
*any* geoserver configuration.
http://docs.codehaus.org/display/GEOSDOC/ComplexLabelingExample
also has an example of SLD-POST and InlineFeature (see the "Dave is
Here!" at the bottom). Hopefully this demo will also ship as either a
downloadable data application, or, better, in the default install.
The main SLD documentation:
http://docs.codehaus.org/display/GEOSDOC/SLD+Explanations+and+Samples
is shaping up.
dave
ps. See next JIRA for some more details.
This mail sent through IMP: https://webmail.limegroup.com/
