Hi Jody,
checking with Alessandro, he had a simple, yet very much to the point, question… how did Ian stumble into the issue?
If OSGeo was mirroring the GeoSolutions fully, maven should not have contacted it for a specific file:
curl “https://maven.geo-solutions.it/net/sf/json-lib/json-lib/2.4.2-geoserver/json-lib-2.4.2-geoserver.pom”
curl: (60) SSL certificate problem: certificate has expired
More details here: https://curl.haxx.se/docs/sslcerts.html
I’m guessing that the OSGeo repository is only selectively mirroring the GeoSoutions repository. I cannot find such a file over there.
That jar is a customized json-lib that we created years ago to handle a vulnerability.
So, if someone wanted to remove the GeoSolutions repos from the build, before that, they’d have to allow full mirroring (or go for a hunt
of every jar we are not finding in the OSGeo repo) and ensure all branches of GeoServer that are still building on Jenkins
will still be able to build on an empty repo.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
