[Geoserver-devel] [Hudson] Build failed in Hudson: 2.2-cite-wcs-1.1 #1195
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1195/&gt;
Started by upstream project "2.2-cite-all" build number 1
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson4290524260601411294.sh
+ ./run.sh wcs-1.1 2.2.x
/var/cache/jetty/data/hudson4290524260601411294.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1196/&gt;
Started by upstream project "2.2-cite-all" build number 2
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson3968719484335655200.sh
/var/cache/jetty/data/hudson3968719484335655200.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1197/&gt;
Started by upstream project "2.2-cite-all" build number 3
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson3193131517061890891.sh
/var/cache/jetty/data/hudson3193131517061890891.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1198/&gt;
Started by upstream project "2.2-cite-all" build number 4
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson3546949499192312430.sh
/var/cache/jetty/data/hudson3546949499192312430.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1199/&gt;
Started by upstream project "2.2-cite-all" build number 5
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson3495867919823531823.sh
/var/cache/jetty/data/hudson3495867919823531823.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1200/&gt;
Started by upstream project "2.2-cite-all" build number 6
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson2178033359731911463.sh
/var/cache/jetty/data/hudson2178033359731911463.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1201/&gt;
Started by upstream project "2.2-cite-all" build number 7
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson6419351144052772320.sh
/var/cache/jetty/data/hudson6419351144052772320.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1202/&gt;
Started by upstream project "2.2-cite-all" build number 8
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson8241754973337405789.sh
/var/cache/jetty/data/hudson8241754973337405789.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1203/&gt;
Started by upstream project "2.2-cite-all" build number 9
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson3895694078252421043.sh
/var/cache/jetty/data/hudson3895694078252421043.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1204/&gt;
Started by upstream project "2.2-cite-all" build number 10
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson4197662265897747593.sh
/var/cache/jetty/data/hudson4197662265897747593.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1205/&gt;
Started by upstream project "2.2-cite-all" build number 11
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson1921624632019759210.sh
/var/cache/jetty/data/hudson1921624632019759210.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1206/&gt;
Started by upstream project "2.2-cite-all" build number 12
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson7321831503470735877.sh
/var/cache/jetty/data/hudson7321831503470735877.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1207/&gt;
Started by upstream project "2.2-cite-all" build number 13
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson899810085682808459.sh
/var/cache/jetty/data/hudson899810085682808459.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1208/&gt;
Started by upstream project "2.2-cite-all" build number 14
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson7407463692641149667.sh
/var/cache/jetty/data/hudson7407463692641149667.sh: 1: ./run.sh: not found
See <http://hudson.opengeo.org/hudson/job/2.2-cite-wcs-1.1/1209/&gt;
Started by upstream project "2.2-cite-all" build number 15
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson5360141524011969225.sh
/var/cache/jetty/data/hudson5360141524011969225.sh: 1: ./run.sh: not found
