[Geoserver-devel] [Hudson] Build failed in Hudson: cite-wcs-1.0-2.3.x #1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/1/&gt;
[...truncated 1824 lines...]
     [exec] VAR_WCS_FORMAT_1:
     [exec] VAR_WCS_COVERAGE_1_POSITION_FIRST:
     [exec] VAR_WCS_COVERAGE_1_POSITION_SECOND:
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-2 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-3 (wcs-1.0.0/d41e1942_1)...
     [exec] Assertion: When a GetCoverage request is made with an invalid RESPONSE_CRS, the server returns service exception.
     [exec] VAR_WCS_TEMP_CRS:
     [exec] VAR_WCS_COVERAGE_1_CRS: You_got_this_because_you_did_not_have_crs_included_in_your_first_domainSet_in_your_first_Coverage
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-3 Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 (wcs-1.0.0/d41e1959_1)...
     [exec] Assertion: When a GetCoverage request is made without version, the server returns service exception.
     [exec] VAR_WCS_COVERAGE_1_BBOX: ,
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 (wcs-1.0.0/d41e1972_1)...
     [exec] Assertion: When a GetCoverage request is made with an invalid version, the server returns service exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 (wcs-1.0.0/d41e1988_1)...
     [exec] Assertion: When a GetCoverage request is made with a version=1.0.0, the server should return the requested content (if other condition satisfied).
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 (wcs-1.0.0/d41e2008_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 (wcs-1.0.0/d41e2029_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 (wcs-1.0.0/d41e2051_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 (wcs-1.0.0/d41e2072_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 (wcs-1.0.0/d41e2093_1)...
     [exec] Assertion: When a GetCoverage request is made with a version an invalid version, the server returns service exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 (wcs-1.0.0/d41e2114_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats (wcs-1.0.0/d41e2326_1)...
     [exec] Assertion: A valid getCoverage response is returned for each of the supportedFormats.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_response-encoding-supportedFormats Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads (wcs-1.0.0/d41e2339_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_response-multifile_payloads Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp (wcs-1.0.0/d41e2355_1)...
     [exec] Assertion: When a GetCoverage request is made with a BBOX partly contained in the defined Bounding BOX, the server returns content.
     [exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP: NaN,NaN,NaN,NaN
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp (wcs-1.0.0/d41e2375_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml (wcs-1.0.0/d41e2396_1)...
     [exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_FIRST: NaN NaN
     [exec] VAR_WCS_COVERAGE_1_BBOX_OVERLAP_POSITION_SECOND: NaN NaN
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp (wcs-1.0.0/d41e2416_1)...
     [exec] Assertion: When a GetCoverage request is made with a BBOX inside the defined Bounding BOX, the server returns content.
     [exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE: NaN,NaN,NaN,NaN
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp (wcs-1.0.0/d41e2436_1)...
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml (wcs-1.0.0/d41e2457_1)...
     [exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_FIRST: NaN NaN
     [exec] VAR_WCS_COVERAGE_1_BBOX_INSIDE_POSITION_SECOND: NaN NaN
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml Failed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden (wcs-1.0.0/d41e2476_1)...
     [exec] Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses resolution parameters to request a coverage that is not at the native resolution returns an exception.
     [exec] VAR_WCS_TEMP_RPCRS:
     [exec] VAR_WCS_COVERAGE_1_RESPONSE_CRS:
     [exec] VAR_WCS_TEMP_INTERPLATION_METHOD:
     [exec] VAR_WCS_INTERPLATION_METHOD: none
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_size-forbidden Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden (wcs-1.0.0/d41e2494_1)...
     [exec] Assertion: If the only interpolation method supported is "none", a GetCoverage request that uses height and width parameters to request a coverage that is not at the native resolution returns an exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-grid_resolution-forbidden Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions (wcs-1.0.0/d41e2512_1)...
     [exec] Assertion: A coverage request using RESX, RESY, RESZ and INTERPOLATION=none raises an exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-resolutions Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs (wcs-1.0.0/d41e2531_1)...
     [exec] Assertion: A coverage request using RESPONSE_CRS and INTERPOLATION=none raises an exception.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-none-response_crs Passed
     [exec] Testing wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method (wcs-1.0.0/d41e2549_1)...
     [exec] Assertion: For each of the advertised interpolation methods, the server returns content.
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-each_interpolation_method Passed
     [exec] Test wcs1-0-0:main Failed (Inherited failure)
     [exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
     [copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/ws/tools/users/geoserver/wcs-1.0.0&gt;
BUILD SUCCESSFUL
Total time: 31 seconds
+ ant wcs-1.0-log
+ grep Failed
     [exec] Test wcs1-0-0:main (wcs-1.0.0) Failed (Inherited Failure)
     [exec] Test wcs1-0-0:basic_service_elements-general_http_request_rules-5 (wcs-1.0.0/d41e585_1) Failed
     [exec] Test wcs1-0-0:basic_service_elements-general_http_request_rules-6 (wcs-1.0.0/d41e596_1) Failed
     [exec] Test wcs1-0-0:basic_service_elements-service_exceptions-1 (wcs-1.0.0/d41e614_1) Failed
     [exec] Test wcs1-0-0:basic_service_elements-version_numbering_and_negotiation-3 (wcs-1.0.0/d41e636_1) Failed
     [exec] Test wcs1-0-0:basic_service_elements-version_numbering_and_negotiation-4 (wcs-1.0.0/d41e643_1) Failed
     [exec] Test wcs1-0-0:describecoverage_operations-describecoverage_request-get-kvp-1 (wcs-1.0.0/d41e650_1) Failed
     [exec] Test wcs1-0-0:describecoverage_operations-describecoverage_request-get-kvp-2 (wcs-1.0.0/d41e657_1) Failed
     [exec] Test wcs1-0-0:describecoverage_operations-describecoverage_request-post-kvp-1 (wcs-1.0.0/d41e731_1) Failed
     [exec] Test wcs1-0-0:describecoverage_operations-describecoverage_request-post-kvp-2 (wcs-1.0.0/d41e743_1) Failed
     [exec] Test wcs1-0-0:describecoverage_operations-describecoverage_request-post-xml-1 (wcs-1.0.0/d41e792_1) Failed
     [exec] Test wcs1-0-0:describecoverage_operations-describecoverage_request-post-xml-2 (wcs-1.0.0/d41e802_1) Failed
     [exec] Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-get-kvp-3 (wcs-1.0.0/d41e895_1) Failed
     [exec] Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-kvp-3 (wcs-1.0.0/d41e973_1) Failed
     [exec] Test wcs1-0-0:getcapabilities_operations-getcapabilities_request-post-xml-3 (wcs-1.0.0/d41e1056_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-exception-get-kvp-1 (wcs-1.0.0/d41e1415_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-exception-post-kvp-1 (wcs-1.0.0/d41e1451_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-interpolationmethod-post-xml-2 (wcs-1.0.0/d41e1684_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-get-kvp-4 (wcs-1.0.0/d41e1744_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-kvp-4 (wcs-1.0.0/d41e1784_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-parameter-post-xml-4 (wcs-1.0.0/d41e1825_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-get-kvp-2 (wcs-1.0.0/d41e1844_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-kvp-2 (wcs-1.0.0/d41e1880_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-response_crs-post-xml-2 (wcs-1.0.0/d41e1920_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-1 (wcs-1.0.0/d41e1959_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-2 (wcs-1.0.0/d41e1972_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-get-kvp-3 (wcs-1.0.0/d41e1988_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-1 (wcs-1.0.0/d41e2008_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-2 (wcs-1.0.0/d41e2029_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-kvp-3 (wcs-1.0.0/d41e2051_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-1 (wcs-1.0.0/d41e2072_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-2 (wcs-1.0.0/d41e2093_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-service_version-post-xml-3 (wcs-1.0.0/d41e2114_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-get-kvp (wcs-1.0.0/d41e2355_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-kvp (wcs-1.0.0/d41e2375_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-partial-post-xml (wcs-1.0.0/d41e2396_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-get-kvp (wcs-1.0.0/d41e2416_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-kvp (wcs-1.0.0/d41e2436_1) Failed
     [exec] Test wcs1-0-0:getcoverage_operations-getcoverage_request-bbox-inside-post-xml (wcs-1.0.0/d41e2457_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/ws/&gt;
+ pushd geoserver/geoserver-2.3-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/ws/geoserver/geoserver-2.3-SNAPSHOT/bin&gt; <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/ws/&gt;
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/2/&gt;
[...truncated 1815 lines...]
BUILD SUCCESSFUL
Total time: 22 seconds
+ ant wcs-1.0-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/3/&gt;
[...truncated 1806 lines...]
BUILD SUCCESSFUL
Total time: 21 seconds
+ ant wcs-1.0-log
+ grep Failed
     [exec] etcapabilities_request-post-kvp-3 (wcs-1.0.0/d41e973_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-2.3.x/4/&gt;
