[Geoserver-devel] [Hudson] Build failed in Hudson: cite-wcs-1.0 #971
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0/971/&gt;
Started by timer
ERROR: Disk quota exceeded
java.io.IOException: Disk quota exceeded
  at java.io.FileOutputStream.writeBytes(Native Method)
  at java.io.FileOutputStream.write(FileOutputStream.java:260)
  at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:202)
  at sun.nio.cs.StreamEncoder.implClose(StreamEncoder.java:297)
  at sun.nio.cs.StreamEncoder.close(StreamEncoder.java:130)
  at java.io.OutputStreamWriter.close(OutputStreamWriter.java:216)
  at hudson.scm.SCM.createEmptyChangeLog(SCM.java:570)
  at hudson.scm.NullSCM.checkout(NullSCM.java:54)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:1479)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:507)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:424)
  at hudson.model.Run.run(Run.java:1366)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:145)
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0/972/&gt;
