See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/752/>
[...truncated 1166 lines...]
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.0.0>
[copy] Copying 38 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/wfs-1.0.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.0.0/ctl>
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.0.0/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/resources>
[copy] Copying 69 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/resources>
[copy] Copying 3 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/wfs-1.1.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/ctl>
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.1.1>
[copy] Copying 18 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/wms-1.1.1>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.1.1/ctl>
[copy] Copying 2 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.1.1/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.3.0>
[copy] Copying 8 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/wms-1.3.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.3.0/ctl>
[copy] Copying 9 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.3.0/ctl>
webapps:
war:
[zip] Building zip: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/setup/teamengine.war>
jar.realm:
compile:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/setup/UserFilesRealm/build>
[javac] <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/setup/UserFilesRealm/build.xml>:13: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/setup/UserFilesRealm/build>
Note: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/setup/UserFilesRealm/src/java/com/occamlab/te/realm/UserFilesRealm.java> uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/setup/UserFilesRealm/build/com/occamlab/te/realm>
jar:
[jar] Building jar: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/setup/UserFilesRealm/UserFilesRealm.jar>
zip.manager.bin:
[delete] Deleting directory <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/build>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/build>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/build/teamengine-2012.09.17>
[copy] Copying 2 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/build/teamengine-2012.09.17>
[zip] Building zip: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/zips/teamengine-manager-2012.09.17-bin.zip>
[INFO] Executed tasks
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/src/test/resources>
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/target/cite-1.0.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/target/cite-1.0.jar> to /usr/share/jetty/.m2/repository/org/geoserver/cite/1.0/cite-1.0.jar
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 21 seconds
[INFO] Finished at: Mon Sep 17 06:16:39 UTC 2012
[INFO] Final Memory: 46M/360M
+ ant clean
Buildfile: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/build.xml>
clean:
BUILD SUCCESSFUL
Total time: 1 second
+ pushd ..
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/> <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools> <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/>
++ pwd
+ FORMS=<http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/forms>
+ popd
+ ant -Dcite.headless=true -Dcite.headless.formroot=<http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/forms> wcs-1.0
wcs-1.0:
run-test:
[exec] Sep 17, 2012 6:16:42 AM com.occamlab.te.Generator generateXsl
[exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/parsers.ctl>
[exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/functions.ctl>
[exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/engine/scripts/wcs-1.0.0/ctl/wcs.xml>
[exec] Checking for <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/forms/wcs-1.0.0.xml>
[exec] Testing suite wcs1-0-0:main_wcs1-0-0...
[exec] Testing wcs1-0-0:main (wcs-1.0.0)...
[exec] Assertion: The WCS 1.0.0 implementation being tested behaves properly
[exec] Sep 17, 2012 6:16:48 AM com.occamlab.te.TECore parse
[exec] SEVERE: parse Error
[exec] java.io.IOException: Server returned HTTP response code: 503 for URL: http://localhost:11010/geoserver/ows?service=wcs&version=1.0.0&request=GetCapabilities
[exec] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1441)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1501)
[exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
[exec] at com.occamlab.te.TECore.request(TECore.java:1123)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
[exec] at sun.reflect.Djava.io.IOException: Server returned HTTP response code: 503 for URL: http://localhost:11010/geoserver/ows?service=wcs&version=1elegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[exec] at java.lang.reflect.Method.invoke(Method.java:597)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
[exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
[exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
[exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
[exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
[exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
[exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
[exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
[exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
[exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
[exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
[exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
[exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
[exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
[exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
[exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
[exec] at com.occamlab.te.TECore.execute(TECore.java:233)
[exec] at com.occamlab.te.Test.main(Test.java:275)
[exec] Fatal Error: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=; SystemID: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/target/work/~2Fvar~2Flib~2Fhudson~2Fcite~2Ftools~2Fengine~2Fscripts~2Fwcs-1.0.0~2Fctl~2Fwcs.xml/wcs1-0-0$main.test;> Line#: 204; Column#: -1
[exec] Sep 17, 2012 6:16:48 AM com.occamlab.te.TECore executeTest
[exec] SEVERE: SaxonApiException
[exec] net.sf.saxon.s9api.SaxonApiException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:192)
[exec] Caused by: net.sf.saxon.trans.XPathException: Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:151)
[exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
[exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
[exec] at net.sf.saxon.expr.LetExpression.proc.0.0&request=GetCapabilities
[exec] Error in call to extension function {public org.w3c.dom.NodeList com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String) throws java.lang.Throwable}: Exception in extension function java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] Test wcs1-0-0:main Failed
[exec] Suite wcs1-0-0:main_wcs1-0-0 Failed
[exec] essLeavingTail(LetExpression.java:551)
[exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:380)
[exec] ... 6 more
[exec] Caused by: java.net.MalformedURLException: no protocol: ?SERVICE=WCS&VERSION=1.0.0&REQUEST=DescribeCoverage&COVERAGE=
[exec] at java.net.URL.<init>(URL.java:567)
[exec] at java.net.URL.<init>(URL.java:464)
[exec] at java.net.URL.<init>(URL.java:413)
[exec] at com.occamlab.te.TECore.build_request(TECore.java:1226)
[exec] at com.occamlab.te.TECore.request(TECore.java:1122)
[exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[exec] ... 56 more
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/tools/users/geoserver/wcs-1.0.0>
BUILD SUCCESSFUL
Total time: 7 seconds
+ ant wcs-1.0-log
+ grep Failed
[exec] Test wcs1-0-0:main (wcs-1.0.0) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.3-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/geoserver/geoserver-2.3-SNAPSHOT/bin> <http://hudson.opengeo.org/hudson/job/cite-wcs-1.0-master/ws/>
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
