[Geoserver-devel] [Hudson] Build failed in Hudson: cite-wcs-1.1 #1111
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/1111/&gt;
[...truncated 2877 lines...]
     [exec] opening square bracket before the axis key is submitted,
     [exec] the response is an exception.
     [exec] Using KVP encoding.
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key Passed
     [exec] Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket (wcs-1.1.1/d41e339_1/d41e12196_1)...
     [exec] Assertion: Verify that when a GetCoverage request using KVP with a missing
     [exec] closing square bracket is submitted, the response is an exception.
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket Passed
     [exec] Testing wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12242_1)...
     [exec] Assertion: Verify that when a GetCoverage request with a format
     [exec] is submitted, the response is not an exception.
     [exec] Test wcs:GetCoverage_Formats Passed
     [exec] Testing wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12266_1)...
     [exec] Using XML encoding.
     [exec] Testing wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12312_1)...
     [exec] Assertion: Verify that when a GetCoverage request with a bogus format
     [exec] is submitted, the response is an exception.
     [exec] Test wcs:GetCoverage_Bogus_Format Passed
     [exec] Testing wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12336_1)...
     [exec] Testing wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12382_1)...
     [exec] Assertion: Verify that when a GetCoverage request with an empty string for
     [exec] the format is submitted, the response is an exception.
     [exec] Test wcs:GetCoverage_Empty_Format Passed
     [exec] Testing wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12406_1)...
     [exec] Testing wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12452_1)...
     [exec] Assertion: Verify that when a GetCoverage request with the format missing
     [exec] Test wcs:GetCoverage_Missing_Format Passed
     [exec] Testing wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12476_1)...
     [exec] Testing wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12522_1)...
     [exec] Assertion: Verify that when a GetCoverage request with a store parameter set
     [exec] to true is submitted, the response is an exception or not depending
     [exec] on the capabilities.
     [exec] Test wcs:GetCoverage_Store_True Passed
     [exec] Testing wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12547_1)...
     [exec] Testing wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12593_1)...
     [exec] set to false is submitted, the response is not an exception.
     [exec] Test wcs:GetCoverage_Store_False Passed
     [exec] Testing wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12617_1)...
     [exec] Testing wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12663_1)...
     [exec] set to a bogus value is submitted, the response is an exception.
     [exec] Sep 11, 2013 7:09:27 AM com.occamlab.te.parsers.XMLValidatingParser parse
     [exec] SEVERE: error parsing
     [exec] org.xml.sax.SAXParseException: CFatal Parsing error at line 1, column 1:
     [exec] Content is not allowed in prolog.
     [exec] 1 validation error detected.
     [exec]
     [exec] Test wcs:Getontent is not allowed in prolog.
     [exec] at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
     [exec] at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
     [exec] at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:124)
     [exec] at com.occamlab.te.parsers.XMLValidatingParser.parse(XMLValidatingParser.java:223)
     [exec] Coverage_Store_Bogus Passed
     [exec] Testing wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12687_1)...
     [exec] AssertgParser.java:170)
     [exec] at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.iion: Verify that when a GetCoverage request with a store parameter
     [exec] set to a bogus value is submitted, the response isnvoke(DelegatingMethodAccessorImpl.java:25)
     [exec] at java.lang.reflect.Method.invoke(Method.java:597)
     [exec] at com.occamlab.te.TECore.pars an exception.
     [exec] Test wcs:GetCoverage_Store_Bogus Passed
     [exec] Test wcs:GetCoverage-main e(TECore.java:1549)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.GeneratedMethodAccessor7.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodFailed (Inherited failure)
     [exec] Test wcs:Main Failed (Inherited failure)
     [exec] Suite wcs:suite Failed
     [exec] AccessorImpl.java:25)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:542)
     [exec] at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:409)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] va:409)
     [exec] at net.sf.saxon.instruct.Choose.processLeavingTail(Choose.java:625)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.callTest(TECore.java:586)
     [exec] at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
     [exec] at net.sf.saxon.expr.Atomizer.iterate(Atomizer.java:163)
     [exec] at net.sf.saxon.expr.FirstItemExpression.evaluateItem(FirstItemExpression.java:93)
     [exec] at net.sf.saxon.expr.CastExpression.evaluateItem(CastExpression.java:316)
     [exec] at net.sf.saxon.instruct.SimpleContentConstructor.evaluateItem(SimpleContentConstructor.java:261)
     [exec] at net.sf.saxon.instruct.ValueOf.processLeavingTail(ValueOf.java:233)
     [copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/users/geoserver/wcs-1.1.1&gt;
BUILD SUCCESSFUL
Total time: 5 minutes 54 seconds
+ ant wcs-1.1-log
+ grep Failed
     [exec] Test wcs:Main (wcs-1.1.1) Failed (Inherited Failure)
     [exec] Test wcs:GetCoverage-main (wcs-1.1.1/d41e339_1) Failed (Inherited Failure)
     [exec] Test wcs:GetCoverage_InsideBoundingBox (wcs-1.1.1/d41e339_1/d41e9696_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/&gt;
+ pushd geoserver/geoserver-2.5-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/geoserver/geoserver-2.5-SNAPSHOT/bin&gt; <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/&gt;
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ ./shutdown.sh
+ (( i <= 100 ))
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/1112/&gt;
