[Geoserver-devel] [Hudson] Build failed in Hudson: cite-wcs-1.1-2.3.x #1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/1/&gt;
[...truncated 2618 lines...]
     [exec] between Axis Keys is submitted, the response is an exception.
     [exec] Using KVP encoding.
     [exec] A DescribeCoverage MinimalRequest initial test case failed. The error is Required paramer, identifiers, missing
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Keys Failed
     [exec] Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Identifier (wcs-1.1.1/d41e339_1/d41e12104_1)...
     [exec] Assertion: Verify that when a GetCoverage request using KVP with a missing
     [exec] opening square bracket before the axis identifier is submitted,
     [exec] the response is an exception.
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Identifier Failed
     [exec] Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key (wcs-1.1.1/d41e339_1/d41e12150_1)...
     [exec] opening square bracket before the axis key is submitted,
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key Failed
     [exec] Testing wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket (wcs-1.1.1/d41e339_1/d41e12196_1)...
     [exec] closing square bracket is submitted, the response is an exception.
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket Failed
     [exec] Testing wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12242_1)...
     [exec] Assertion: Verify that when a GetCoverage request with a format
     [exec] is submitted, the response is not an exception.
     [exec] Test wcs:GetCoverage_Formats Failed
     [exec] Testing wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12266_1)...
     [exec] Using XML encoding.
     [exec] A DescribeCoverage MinimalRequest initial test case failed. The error is Parsing failed, the xml request is most probably not compliant to the wcs schema
     [exec] cvc-pattern-valid: Value &apos;&apos; is not facet-valid with respect to pattern &apos;.+&apos; for type &apos;IdentifierType&apos;.
     [exec] Testing wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12312_1)...
     [exec] Assertion: Verify that when a GetCoverage request with a bogus format
     [exec] is submitted, the response is an exception.
     [exec] Test wcs:GetCoverage_Bogus_Format Failed
     [exec] Testing wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12336_1)...
     [exec] Testing wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12382_1)...
     [exec] Assertion: Verify that when a GetCoverage request with an empty string for
     [exec] the format is submitted, the response is an exception.
     [exec] Test wcs:GetCoverage_Empty_Format Failed
     [exec] Testing wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12406_1)...
     [exec] Testing wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12452_1)...
     [exec] Assertion: Verify that when a GetCoverage request with the format missing
     [exec] Test wcs:GetCoverage_Missing_Format Failed
     [exec] Testing wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12476_1)...
     [exec] Testing wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12522_1)...
     [exec] Assertion: Verify that when a GetCoverage request with a store parameter set
     [exec] to true is submitted, the response is an exception or not depending
     [exec] on the capabilities.
     [exec] Test wcs:GetCoverage_Store_True Failed
     [exec] Testing wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12547_1)...
     [exec] Testing wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12593_1)...
     [exec] set to false is submitted, the response is not an exception.
     [exec] Test wcs:GetCoverage_Store_False Failed
     [exec] Testing wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12617_1)...
     [exec] Testing wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12663_1)...
     [exec] set to a bogus value is submitted, the response is an exception.
     [exec] Test wcs:GetCoverage_Store_Bogus Failed
     [exec] Testing wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12687_1)...
     [exec] Test wcs:GetCoverage-main Failed (Inherited failure)
     [exec] Test wcs:Main Failed (Inherited failure)
     [exec] Suite wcs:suite Failed
     [copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/ws/tools/users/geoserver/wcs-1.1.1&gt;
BUILD SUCCESSFUL
Total time: 56 seconds
+ ant wcs-1.1-log
+ grep Failed
     [exec] Test wcs:Main (wcs-1.1.1) Failed (Inherited Failure)
     [exec] Test wcs:GetCapabilities-main (wcs-1.1.1/d41e329_1) Failed (Inherited Failure)
     [exec] Test wcs:GetCapabilities_Sections_ServiceProvider (wcs-1.1.1/d41e329_1/d41e798_1) Failed
     [exec] Test wcs:GetCapabilities_Sections_ServiceProvider (wcs-1.1.1/d41e329_1/d41e825_1) Failed
     [exec] Test wcs:GetCapabilities_Sections_Contents (wcs-1.1.1/d41e329_1/d41e950_1) Failed
     [exec] Test wcs:GetCapabilities_Sections_Contents (wcs-1.1.1/d41e329_1/d41e977_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Title (wcs-1.1.1/d41e329_1/d41e2609_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Abstract (wcs-1.1.1/d41e329_1/d41e2649_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_SupportedFormat (wcs-1.1.1/d41e329_1/d41e2689_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_SupportedCRS (wcs-1.1.1/d41e329_1/d41e2729_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Identifier (wcs-1.1.1/d41e329_1/d41e2769_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Identifier_XML (wcs-1.1.1/d41e329_1/d41e2809_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_SupportedFormat_XML (wcs-1.1.1/d41e329_1/d41e2849_1) Failed
     [exec] Test wcs:GetCapabilities_Response_OperationsMetadata_Contents_CoverageSummary_Identifier_Unique (wcs-1.1.1/d41e329_1/d41e2889_1) Failed
     [exec] Test wcs:DescribeCoverage-main (wcs-1.1.1/d41e334_1) Failed (Inherited Failure)
     [exec] Test wcs:DescribeCoverage_Response_InterpolationMethods (wcs-1.1.1/d41e334_1/d41e7337_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_InterpolationMethods (wcs-1.1.1/d41e334_1/d41e7361_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_Identifier_XML (wcs-1.1.1/d41e334_1/d41e7407_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_Identifier_XML (wcs-1.1.1/d41e334_1/d41e7431_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_SupportedFormat_XML (wcs-1.1.1/d41e334_1/d41e7477_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_SupportedFormat_XML (wcs-1.1.1/d41e334_1/d41e7501_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_FieldIdentifier_XML (wcs-1.1.1/d41e334_1/d41e7547_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_FieldIdentifier_XML (wcs-1.1.1/d41e334_1/d41e7571_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_InterpolationMethod_XML (wcs-1.1.1/d41e334_1/d41e7617_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_InterpolationMethod_XML (wcs-1.1.1/d41e334_1/d41e7642_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_AxisIdentifier_XML (wcs-1.1.1/d41e334_1/d41e7688_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_AxisIdentifier_XML (wcs-1.1.1/d41e334_1/d41e7712_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_AxisKey_XML (wcs-1.1.1/d41e334_1/d41e7758_1) Failed
     [exec] Test wcs:DescribeCoverage_Response_AxisKey_XML (wcs-1.1.1/d41e334_1/d41e7782_1) Failed
     [exec] Test wcs:GetCoverage-main (wcs-1.1.1/d41e339_1) Failed (Inherited Failure)
     [exec] Test wcs:GetCoverage_MinimalRequest (wcs-1.1.1/d41e339_1/d41e9275_1) Failed
     [exec] Test wcs:GetCoverage_MinimalRequest (wcs-1.1.1/d41e339_1/d41e9299_1) Failed
     [exec] Test wcs:GetCoverage_MissingIdentifier (wcs-1.1.1/d41e339_1/d41e9345_1) Failed
     [exec] Test wcs:GetCoverage_MissingIdentifier (wcs-1.1.1/d41e339_1/d41e9369_1) Failed
     [exec] Test wcs:GetCoverage_EmptyIdentifier (wcs-1.1.1/d41e339_1/d41e9415_1) Failed
     [exec] Test wcs:GetCoverage_EmptyIdentifier (wcs-1.1.1/d41e339_1/d41e9439_1) Failed
     [exec] Test wcs:GetCoverage_BogusIdentifier (wcs-1.1.1/d41e339_1/d41e9485_1) Failed
     [exec] Test wcs:GetCoverage_BogusIdentifier (wcs-1.1.1/d41e339_1/d41e9509_1) Failed
     [exec] Test wcs:GetCoverage_MissingBoundingBox (wcs-1.1.1/d41e339_1/d41e9555_1) Failed
     [exec] Test wcs:GetCoverage_MissingBoundingBox (wcs-1.1.1/d41e339_1/d41e9579_1) Failed
     [exec] Test wcs:GetCoverage_SurroundingBoundingBox (wcs-1.1.1/d41e339_1/d41e9625_1) Failed
     [exec] Test wcs:GetCoverage_SurroundingBoundingBox (wcs-1.1.1/d41e339_1/d41e9650_1) Failed
     [exec] Test wcs:GetCoverage_InsideBoundingBox (wcs-1.1.1/d41e339_1/d41e9696_1) Failed
     [exec] Test wcs:GetCoverage_InsideBoundingBox (wcs-1.1.1/d41e339_1/d41e9720_1) Failed
     [exec] Test wcs:GetCoverage_OverlappingBoundingBox (wcs-1.1.1/d41e339_1/d41e9766_1) Failed
     [exec] Test wcs:GetCoverage_OverlappingBoundingBox (wcs-1.1.1/d41e339_1/d41e9790_1) Failed
     [exec] Test wcs:GetCoverage_BoundingBox_OutOfRangeCoordinates (wcs-1.1.1/d41e339_1/d41e9836_1) Failed
     [exec] Test wcs:GetCoverage_BoundingBox_OutOfRangeCoordinates (wcs-1.1.1/d41e339_1/d41e9860_1) Failed
     [exec] Test wcs:GetCoverage_OutsideBoundingBox (wcs-1.1.1/d41e339_1/d41e9906_1) Failed
     [exec] Test wcs:GetCoverage_OutsideBoundingBox (wcs-1.1.1/d41e339_1/d41e9930_1) Failed
     [exec] Test wcs:GetCoverage_AntimeridianBoundingBox (wcs-1.1.1/d41e339_1/d41e9976_1) Failed
     [exec] Test wcs:GetCoverage_AntimeridianBoundingBox (wcs-1.1.1/d41e339_1/d41e10000_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Identifier (wcs-1.1.1/d41e339_1/d41e10865_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Identifier (wcs-1.1.1/d41e339_1/d41e10889_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Repeated_Identifiers (wcs-1.1.1/d41e339_1/d41e11038_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Repeated_Identifiers (wcs-1.1.1/d41e339_1/d41e11062_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Bogus_Identifier (wcs-1.1.1/d41e339_1/d41e11108_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Bogus_Identifier (wcs-1.1.1/d41e339_1/d41e11132_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Valid_With_Bogus_Identifiers (wcs-1.1.1/d41e339_1/d41e11178_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Valid_With_Bogus_Identifiers (wcs-1.1.1/d41e339_1/d41e11202_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_InterpolationMethod (wcs-1.1.1/d41e339_1/d41e11248_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_InterpolationMethod (wcs-1.1.1/d41e339_1/d41e11272_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Missing (wcs-1.1.1/d41e339_1/d41e11318_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Missing (wcs-1.1.1/d41e339_1/d41e11342_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Bogus (wcs-1.1.1/d41e339_1/d41e11388_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_InterpolationMethod_Bogus (wcs-1.1.1/d41e339_1/d41e11413_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_One_Key (wcs-1.1.1/d41e339_1/d41e11459_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_One_Key (wcs-1.1.1/d41e339_1/d41e11483_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Some_Keys (wcs-1.1.1/d41e339_1/d41e11529_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Some_Keys (wcs-1.1.1/d41e339_1/d41e11553_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_All_Keys (wcs-1.1.1/d41e339_1/d41e11599_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_All_Keys (wcs-1.1.1/d41e339_1/d41e11623_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_No_Key (wcs-1.1.1/d41e339_1/d41e11669_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_No_Key (wcs-1.1.1/d41e339_1/d41e11693_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Bogus_Key (wcs-1.1.1/d41e339_1/d41e11739_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_Axis_Identifier_Bogus_Key (wcs-1.1.1/d41e339_1/d41e11763_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Field_Identifier_And_InterpolationMethod (wcs-1.1.1/d41e339_1/d41e11966_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Identifiers (wcs-1.1.1/d41e339_1/d41e12012_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Semicolon_Between_Axis_Keys (wcs-1.1.1/d41e339_1/d41e12058_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Identifier (wcs-1.1.1/d41e339_1/d41e12104_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Opening_Square_Bracket_Before_Axis_Key (wcs-1.1.1/d41e339_1/d41e12150_1) Failed
     [exec] Test wcs:GetCoverage_RangeSubset_KVP_Syntax_Missing_Closing_Square_Bracket (wcs-1.1.1/d41e339_1/d41e12196_1) Failed
     [exec] Test wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12242_1) Failed
     [exec] Test wcs:GetCoverage_Formats (wcs-1.1.1/d41e339_1/d41e12266_1) Failed
     [exec] Test wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12312_1) Failed
     [exec] Test wcs:GetCoverage_Bogus_Format (wcs-1.1.1/d41e339_1/d41e12336_1) Failed
     [exec] Test wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12382_1) Failed
     [exec] Test wcs:GetCoverage_Empty_Format (wcs-1.1.1/d41e339_1/d41e12406_1) Failed
     [exec] Test wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12452_1) Failed
     [exec] Test wcs:GetCoverage_Missing_Format (wcs-1.1.1/d41e339_1/d41e12476_1) Failed
     [exec] Test wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12522_1) Failed
     [exec] Test wcs:GetCoverage_Store_True (wcs-1.1.1/d41e339_1/d41e12547_1) Failed
     [exec] Test wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12593_1) Failed
     [exec] Test wcs:GetCoverage_Store_False (wcs-1.1.1/d41e339_1/d41e12617_1) Failed
     [exec] Test wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12663_1) Failed
     [exec] Test wcs:GetCoverage_Store_Bogus (wcs-1.1.1/d41e339_1/d41e12687_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/ws/&gt;
+ pushd geoserver/geoserver-2.3-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/ws/geoserver/geoserver-2.3-SNAPSHOT/bin&gt; <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/ws/&gt;
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/2/&gt;
[...truncated 2600 lines...]
BUILD SUCCESSFUL
Total time: 39 seconds
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ ./shutdown.sh
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/3/&gt;
BUILD SUCCESSFUL
Total time: 34 seconds
+ ant wcs-1.1-log
+ grep Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1-2.3.x/4/&gt;
