See <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/975/>
[...truncated 1148 lines...]
jar.components:
jar.component:
compile:
[javac] <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/components/cite1/build.xml>:15: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
jar:
webapp.components:
webapp.component:
[copy] Copying 10 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/classes>
[copy] Copying 8 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/lib>
build.scripts:
build.script:
build.script:
build.script:
build.script:
xinclude:
zip:
all:
build.script:
build.script:
data:
webapp.scripts:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.0.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.0.0/resources>
[copy] Copying 17 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.0.0/resources>
[copy] Copying 5 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/wcs-1.0.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.0.0/ctl>
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.0.0/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.1.1>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.1.1/resources>
[copy] Copying 60 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.1.1/resources>
[copy] Copying 2 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/wcs-1.1.1>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.1.1/ctl>
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wcs-1.1.1/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.0.0>
[copy] Copying 38 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/wfs-1.0.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.0.0/ctl>
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.0.0/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/resources>
[copy] Copying 69 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/resources>
[copy] Copying 3 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/wfs-1.1.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/ctl>
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wfs-1.1.0/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.1.1>
[copy] Copying 18 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/wms-1.1.1>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.1.1/ctl>
[copy] Copying 2 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.1.1/ctl>
webapp.script:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.3.0>
[copy] Copying 8 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/wms-1.3.0>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.3.0/ctl>
[copy] Copying 9 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/webapps/teamengine/WEB-INF/scripts/wms-1.3.0/ctl>
webapps:
war:
[zip] Building zip: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/setup/teamengine.war>
jar.realm:
compile:
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/setup/UserFilesRealm/build>
[javac] <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/setup/UserFilesRealm/build.xml>:13: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/setup/UserFilesRealm/build>
Note: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/setup/UserFilesRealm/src/java/com/occamlab/te/realm/UserFilesRealm.java> uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/setup/UserFilesRealm/build/com/occamlab/te/realm>
jar:
[jar] Building jar: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/setup/UserFilesRealm/UserFilesRealm.jar>
zip.manager.bin:
[delete] Deleting directory <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/build>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/build>
[mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/build/teamengine-2013.01.23>
[copy] Copying 2 files to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/build/teamengine-2013.01.23>
[zip] Building zip: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/zips/teamengine-manager-2013.01.23-bin.zip>
[INFO] Executed tasks
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/src/test/resources>
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/target/cite-1.0.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/target/cite-1.0.jar> to /usr/share/jetty/.m2/repository/org/geoserver/cite/1.0/cite-1.0.jar
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 32 seconds
[INFO] Finished at: Wed Jan 23 05:28:54 UTC 2013
[INFO] Final Memory: 47M/388M
+ ant clean
Buildfile: <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/build.xml>
clean:
BUILD SUCCESSFUL
Total time: 0 seconds
+ pushd ..
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/> <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools> <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/>
++ pwd
+ FORMS=<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/forms>
+ popd
+ ant -Dcite.headless=true -Dcite.headless.formroot=<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/forms> wcs-1.1
wcs-1.1:
run-test:
[exec] Jan 23, 2013 5:28:57 AM com.occamlab.te.Generator generateXsl
[exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/parsers.ctl>
[exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/functions.ctl>
[exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/engine/scripts/wcs-1.1.1/ctl/wcs.xml>
[exec] Testing suite wcs:suite...
[exec] Testing wcs:Main (wcs-1.1.1)...
[exec] Assertion: The Implementation Under Test (IUT) satisfies all applicable
[exec] assertions. There are 177 tests in total. Depending on the capabilities
[exec] of the server, some tests are skipped. These are recorded in the
[exec] detailed results for each type of request.
[exec] Checking for <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/forms/wcs-1.1.1.xml>
[exec] WCS 1.1.1 URL is http://localhost:11010/geoserver/ows.
[exec] Testing wcs:GetCapabilities-main (wcs-1.1.1/d41e329_1)...
[exec] Assertion: All assertions for "GetCapabilities" conformance are satisfied.
[exec] Validation error:
[exec] cvc-elt.1: Cannot find the declaration of element 'ows:ExceptionReport'.
[exec] 1 validation error detected.
[exec]
[exec]
[exec] The service metadata document has version but expected to find 1.1.1 as the highest protocol supported. See OGC 06-121r3 subclause 7.3.2.
[exec]
[exec] The server seems to have a problem with handling the GetCapabilities sections parameter. No tests will be performed.
[exec] The EqualUpdateSequence value is .
[exec] The URL for KVP encoding is .
[exec] The URL for XML encoding is .
[exec] XML encoding is not supported.
[exec] sections-supported: false.
[exec] Test wcs:GetCapabilities-main Failed
[exec] Testing wcs:DescribeCoverage-main (wcs-1.1.1/d41e334_1)...
[exec] Assertion: All assertions for "DescribeCoverage" conformance are satisfied.
[exec]
[exec]
[exec]
[exec] Identifier1 is .
[exec] Identifier2 is .
[exec] Identifier3 is .
[exec] Test wcs:DescribeCoverage-main Failed
[exec] Testing wcs:GetCoverage-main (wcs-1.1.1/d41e339_1)...
[exec] Assertion: All assertions for "GetCoverage" conformance are satisfied.
[exec]
[exec]
[exec]
[exec] store supported is false.
[exec] Test wcs:GetCoverage-main Failed
[exec] Test wcs:Main Failed (Inherited failure)
[exec] Suite wcs:suite Failed
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/tools/users/geoserver/wcs-1.1.1>
BUILD SUCCESSFUL
Total time: 14 seconds
+ ant wcs-1.1-log
+ grep Failed
[exec] Test wcs:Main (wcs-1.1.1) Failed (Inherited Failure)
[exec] Test wcs:GetCapabilities-main (wcs-1.1.1/d41e329_1) Failed
[exec] Test wcs:DescribeCoverage-main (wcs-1.1.1/d41e334_1) Failed
[exec] Test wcs:GetCoverage-main (wcs-1.1.1/d41e339_1) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.2-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/geoserver/geoserver-2.2-SNAPSHOT/bin> <http://hudson.opengeo.org/hudson/job/cite-wcs-1.1/ws/>
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
