See <http://hudson.opengeo.org/hudson/job/cite-wms-1.1-master/780/>
[...truncated 1491 lines...]
[exec] Assertion: The server interprets the bounding box as going around the "outside" of the pixels of the image rather than through the centers of the border pixels.
[exec] Test wms:wmsops-getmap-params-bbox-4 Passed
[exec] Testing wms:wmsops-getmap-params-bbox-5 (wms-1.1.1/d247e1444_1)...
[exec] Assertion: When the BBOX parameter's minimum X is greater than the maximum X, then the server throws an exception.
[exec] Test wms:wmsops-getmap-params-bbox-5 Passed
[exec] Testing wms:wmsops-getmap-params-bbox-6 (wms-1.1.1/d247e1458_1)...
[exec] Assertion: When the BBOX parameter's minimum X is equal to the maximum X, then the server throws an exception.
[exec] Test wms:wmsops-getmap-params-bbox-6 Passed
[exec] Testing wms:wmsops-getmap-params-bbox-7 (wms-1.1.1/d247e1472_1)...
[exec] Assertion: When the BBOX parameter's minimum Y is greater than the maximum Y, then the server throws an exception.
[exec] Test wms:wmsops-getmap-params-bbox-7 Passed
[exec] Testing wms:wmsops-getmap-params-bbox-8 (wms-1.1.1/d247e1487_1)...
[exec] Assertion: When the BBOX parameter's minimum Y is equal to the maximum Y, then the server throws an exception.
[exec] Test wms:wmsops-getmap-params-bbox-8 Passed
[exec] Testing wms:wmsops-getmap-params-bbox-9 (wms-1.1.1/d247e1501_1)...
[exec] Assertion: When a request contains a Bounding Box whose area does not overlap at all with the BoundingBox advertised, then the server returns empty content.
[exec] Test wms:wmsops-getmap-params-bbox-9 Passed
[exec] Testing wms:wmsops-getmap-params-bgcolor-1 (wms-1.1.1/d247e1515_1)...
[exec] Assertion: When a GetMap request is made with no BGCOLOR parameter, then areas which are not covered contain white (0xFFFFFF) pixels.
[exec] Test wms:wmsops-getmap-params-bgcolor-1 Passed
[exec] Testing wms:wmsops-getmap-params-bgcolor-2 (wms-1.1.1/d247e1529_1)...
[exec] Assertion: When a GetMap request is made with a BGCOLOR parameter, then areas which are not covered are set to the value of BGCOLOR.
[exec] Test wms:wmsops-getmap-params-bgcolor-2 Passed
[exec] Testing wms:wmsops-getmap-params-exceptions-1 (wms-1.1.1/d247e1541_1)...
[exec] Assertion: When an exception is raised without specifying the EXCEPTIONS parameter, then the Content-type of the return header is application/vnd.ogc.se_xml.
[exec] Test wms:wmsops-getmap-params-exceptions-1 Passed
[exec] Testing wms:wmsops-getmap-params-exceptions-2 (wms-1.1.1/d247e1550_1)...
[exec] Assertion: When an exception is raised and EXCEPTIONS=application/vnd.ogc.se_xml, then the Content-type of the return header is application/vnd.ogc.se_xml.
[exec] Test wms:wmsops-getmap-params-exceptions-2 Passed
[exec] Testing wms:wmsops-getmap-params-exceptions-4 (wms-1.1.1/d247e1562_1)...
[exec] Assertion: When an exception is raised and EXCEPTIONS=application/vnd.ogc.se_inimage, then the Content-type of the return header is the same as the FORMAT requested.
[exec] Test wms:wmsops-getmap-params-exceptions-4 Passed
[exec] Testing wms:wmsops-getmap-params-format-1 (wms-1.1.1/d247e1610_1)...
[exec] Assertion: When a GetMap request contains a Format that is not advertised, then the server throws a Service Exception (code="InvalidFormat").
[exec] Test wms:wmsops-getmap-params-format-1 Passed
[exec] Testing wms:wmsops-getmap-params-format-2 (wms-1.1.1/d247e1622_1)...
[exec] Assertion: When a GetMap request is made using format=image/gif, then the response is a valid gif.
[exec] VAR_IMAGE_TYPE: gif
[exec] Test wms:wmsops-getmap-params-format-2 Passed
[exec] Testing wms:wmsops-getmap-params-format-3 (wms-1.1.1/d247e1635_1)...
[exec] Assertion: When a GetMap request is made using format=image/jpeg, then the response is a valid jpeg.
[exec] VAR_IMAGE_TYPE: jpeg
[exec] Test wms:wmsops-getmap-params-format-3 Passed
[exec] Testing wms:wmsops-getmap-params-format-4 (wms-1.1.1/d247e1647_1)...
[exec] Assertion: When a GetMap request is made using format=image/png, then the response is a valid png.
[exec] VAR_IMAGE_TYPE: png
[exec] Test wms:wmsops-getmap-params-format-4 Passed
[exec] Testing wms:wmsops-getmap-params-layers-1 (wms-1.1.1/d247e1659_1)...
[exec] Assertion: When a GetMap request contains a single layer name, then the response is valid.
[exec] Test wms:wmsops-getmap-params-layers-1 Passed
[exec] Testing wms:wmsops-getmap-params-layers-2 (wms-1.1.1/d247e1673_1)...
[exec] Assertion: When a GetMap request contains two layer names (separated by a comma), then the response is valid.
[exec] Test wms:wmsops-getmap-params-layers-2 Passed
[exec] Testing wms:wmsops-getmap-params-layers-3 (wms-1.1.1/d247e1689_1)...
[exec] Assertion: When a GetMap request contains three layer names (separated by commas), then the response is valid.
[exec] Test wms:wmsops-getmap-params-layers-3 Passed
[exec] Testing wms:wmsops-getmap-params-layers-5 (wms-1.1.1/d247e1706_1)...
[exec] Assertion: When the layer in a GetMap request is invalid, then the response is an exception (code="LayerNotDefined").
[exec] Test wms:wmsops-getmap-params-layers-5 Passed
[exec] Testing wms:wmsops-getmap-params-layers-6 (wms-1.1.1/d247e1718_1)...
[exec] Assertion: When a GetMap request contains two layers where the first is valid and the second is invalid, then the response is an exception (code="LayerNotDefined").
[exec] Test wms:wmsops-getmap-params-layers-6 Passed
[exec] Testing wms:wmsops-getmap-params-layers-7 (wms-1.1.1/d247e1732_1)...
[exec] Assertion: When a GetMap request contains two layers where the first is invalid and the second is valid, then the response is an exception (code="LayerNotDefined").
[exec] Test wms:wmsops-getmap-params-layers-7 Passed
[exec] Testing wms:wmsops-getmap-params-request-1 (wms-1.1.1/d247e1746_1)...
[exec] Assertion: When a GetMap request is made using REQUEST=map instead of REQUEST=GetMap, the response is valid.
[exec] Test wms:wmsops-getmap-params-request-1 Passed
[exec] Testing wms:wmsops-getmap-params-srs-1 (wms-1.1.1/d247e1760_1)...
[exec] Assertion: When a GetMap request contains a single layer and a SRS where the SRS is contained directly in the layer in the capabilities document, then the response is valid.
[exec] Test wms:wmsops-getmap-params-srs-1 Passed
[exec] Testing wms:wmsops-getmap-params-srs-3 (wms-1.1.1/d247e1788_1)...
[exec] Assertion: When the SRS parameter in a GetMap request contains a SRS that is not valid for any of the layers being requested, then the server shall throw a Service Exception (code = "InvalidSRS").
[exec] Test wms:wmsops-getmap-params-srs-3 Passed
[exec] Testing wms:wmsops-getmap-params-styles-1 (wms-1.1.1/d247e1803_1)...
[exec] Assertion: When a GetMap request contains a single layer and a single style where the style is contained directly in the layer in the capabilities document, then the response is valid.
[exec] Test wms:wmsops-getmap-params-styles-1 Passed
[exec] Testing wms:wmsops-getmap-params-styles-10 (wms-1.1.1/d247e1819_1)...
[exec] Assertion: When a GetMap request contains two layers, where one of the styles is valid and one is not, then the response is an exception (code=StyleNotDefined).
[exec] Test wms:wmsops-getmap-params-styles-10 Passed
[exec] Testing wms:wmsops-getmap-params-styles-3 (wms-1.1.1/d247e1854_1)...
[exec] Assertion: When a GetMap request contains two layers and two styles (separated by a comma), then the response is valid.
[exec] Test wms:wmsops-getmap-params-styles-3 Passed
[exec] Testing wms:wmsops-getmap-params-styles-4 (wms-1.1.1/d247e1870_1)...
[exec] Assertion: When a GetMap request contains three layers and three styles (separated by commas), then the response is valid.
[exec] Test wms:wmsops-getmap-params-styles-4 Passed
[exec] Testing wms:wmsops-getmap-params-styles-5 (wms-1.1.1/d247e1886_1)...
[exec] Assertion: When a GetMap request contains an unadvertised Style, then the response is an exception (code=StyleNotDefined).
[exec] Test wms:wmsops-getmap-params-styles-5 Passed
[exec] Testing wms:wmsops-getmap-params-styles-6 (wms-1.1.1/d247e1901_1)...
[exec] Assertion: When a GetMap request contains a single layer and a null style value (as in "STYLES="), then the response is valid.
[exec] Test wms:wmsops-getmap-params-styles-6 Passed
[exec] Testing wms:wmsops-getmap-params-styles-7 (wms-1.1.1/d247e1915_1)...
[exec] Assertion: When a GetMap request contains multiple layers and a mixture of named and default styles (as in "STYLES=style1,style2,"), then the response is valid.
[exec] Test wms:wmsops-getmap-params-styles-7 Passed
[exec] Testing wms:wmsops-getmap-params-styles-8 (wms-1.1.1/d247e1938_1)...
[exec] Assertion: When a GetMap request contains multiple layers and requests all layers to be shown in the default style by using null values between commas (as in "STYLES=,"), then the response is valid.
[exec] Test wms:wmsops-getmap-params-styles-8 Passed
[exec] Testing wms:wmsops-getmap-params-styles-9 (wms-1.1.1/d247e1959_1)...
[exec] Assertion: When a GetMap request contains multiple layers and requests all layers to be shown in the default style by using a single null value (as in "STYLES="), then the response is valid.
[exec] Test wms:wmsops-getmap-params-styles-9 Passed
[exec] Testing wms:wmsops-getmap-params-transparent-1 (wms-1.1.1/d247e1980_1)...
[exec] Assertion: When a GetMap request is made with no TRANSPARENT parameter and a FORMAT that supports transparency over a BBOX that is not completely covered, then the response contains no transparent pixels.
[exec] Test wms:wmsops-getmap-params-transparent-1 Passed
[exec] Testing wms:wmsops-getmap-params-transparent-2 (wms-1.1.1/d247e1994_1)...
[exec] Assertion: When a GetMap request is made with TRANSPARENT=fAlSe and a FORMAT that supports transparency over a BBOX that is not completely covered, then the response contains no transparent pixels.
[exec] Test wms:wmsops-getmap-params-transparent-2 Passed
[exec] Testing wms:wmsops-getmap-params-transparent-3 (wms-1.1.1/d247e2009_1)...
[exec] Assertion: When a GetMap request is made with TRANSPARENT=TRUE and a FORMAT that supports transparency over a BBOX that is not completely covered, then the response contains transparent pixels.
[exec] Test wms:wmsops-getmap-params-transparent-3 Passed
[exec] Testing wms:wmsops-getmap-params-version-1 (wms-1.1.1/d247e2023_1)...
[exec] Assertion: When a GetMap request is made using WMTVER instead of VERSION, the response is valid.
[exec] Test wms:wmsops-getmap-params-version-1 Passed
[exec] Testing wms:wmsops-getmap-params-width_height-1 (wms-1.1.1/d247e2037_1)...
[exec] Assertion: When a request is made with WIDTH=1024 and HEIGHT=768, the image returned is exactly the size requested.
[exec] Test wms:wmsops-getmap-params-width_height-1 Passed
[exec] Testing wms:wmsops-getmap-params-width_height-2 (wms-1.1.1/d247e2056_1)...
[exec] Assertion: When a request is made with WIDTH=16 and HEIGHT=16, the image returned is exactly the size requested.
[exec] Test wms:wmsops-getmap-params-width_height-2 Passed
[exec] Testing wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d247e2072_1)...
[exec] Assertion: For each advertised GetFeatureInfo format, when a GetFeatureInfo request is made with the INFO_FORMAT parameter set to the format, then the Content-type header returned is the same.
[exec] Test wms:wmsops-getfeatureinfo-each-info_format Passed
[exec] Testing wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d247e2072_2)...
[exec] Testing wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d247e2072_3)...
[exec] Test wms:wmsops-getfeatureinfo-each-info_format Failed
[exec] Testing wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d247e2072_4)...
[exec] Testing wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d247e2072_5)...
[exec] Testing wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d247e2072_6)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_1)...
[exec] Assertion: For each of the Styles in the capabilities document, when a GetMap request is made with the STYLES parameter set to the element of the style, then the response is valid.
[exec] Test wms:wmsops-getmap-each-style Passed
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_2)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_3)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_4)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_5)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_6)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_7)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_8)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_9)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_10)...
[exec] Testing wms:wmsops-getmap-each-style (wms-1.1.1/d247e2083_11)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_1)...
[exec] Assertion: For each of the Layers in the capabilities document, when a GetMap request is made with the LAYERS parameter set to the element of the layer, then the response is valid.
[exec] Test wms:wmsops-getmap-each-layer Passed
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_2)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_3)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_4)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_5)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_6)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_7)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_8)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_9)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_10)...
[exec] Testing wms:wmsops-getmap-each-layer (wms-1.1.1/d247e2093_11)...
[exec] Testing wms:wmsops-getmap-each-srs (wms-1.1.1/d247e2103_1)...
[exec] Assertion: For each SRS in the capabilities document, when a GetMap request uses the SRS, then the response is valid.
[exec] Test wms:wmsops-getmap-each-srs Passed
[exec] Testing wms:wmsops-getmap-layer-encoded-name (wms-1.1.1/d247e2131_1)...
[exec] Assertion: When a layer is requested using encoded characters in its name, the response is a map.
[exec] Test wms:wmsops-getmap-layer-encoded-name Passed
[exec] Testing wms:basic_elements-validate-exception (wms-1.1.1/d247e2137_1)...
[exec] Assertion: When an exception is generated, it validates.
[exec] Test wms:basic_elements-validate-exception Passed
[exec] Test wms:wms_main Failed (Inherited failure)
[exec] Suite wms:main_wms Failed
[copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wms-1.1-master/ws/tools/users/geoserver/wms-1.1.1>
BUILD SUCCESSFUL
Total time: 31 seconds
+ ant wms-1.1-log
+ grep Failed
[exec] Test wms:wms_main (wms-1.1.1) Failed (Inherited Failure)
[exec] Test wms:wmsops-getfeatureinfo-each-info_format (wms-1.1.1/d247e2072_3) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-master/ws/>
+ pushd geoserver/geoserver-2.3-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wms-1.1-master/ws/geoserver/geoserver-2.3-SNAPSHOT/bin> <http://hudson.opengeo.org/hudson/job/cite-wms-1.1-master/ws/>
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver’
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
