[Geoserver-devel] [Hudson] Build failed in Hudson: cite-wms-1.3-master #516
See <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-master/516/&gt;
[...truncated 1882 lines...]
     [exec] Test getmap:each-style Passed
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_4)...
     [exec] Assertion: For style "Buildings", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_5)...
     [exec] Assertion: For style "DividedRoutes", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_6)...
     [exec] Assertion: For style "Forests", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_7)...
     [exec] Assertion: For style "Lakes", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_8)...
     [exec] Assertion: For style "polygon", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_9)...
     [exec] Assertion: For style "MapNeatline", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_10)...
     [exec] Assertion: For style "NamedPlaces", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_11)...
     [exec] Assertion: For style "Ponds", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_12)...
     [exec] Assertion: For style "RoadSegments", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Testing getmap:each-style (wms-1.3.0/d3717e372_1/d1097e54_1/d1097e317_13)...
     [exec] Assertion: For style "Streams", when the STYLES parameter is set to that style name, the MIME type of the response is valid.
     [exec] Test getmap:styles Passed
     [exec] Testing getmap:transparent (wms-1.3.0/d3717e372_1/d1097e56_1)...
     [exec] Assertion: The TRANSPARENT parameter behaves properly.
     [exec] Testing getmap:transparent-default (wms-1.3.0/d3717e372_1/d1097e56_1/d1097e339_1)...
     [exec] Assertion: When a GetMap request is made with no TRANSPARENT parameter and a FORMAT that supports transparency over a layer that is not opaque, then the response contains no transparent pixels.
     [exec] Test getmap:transparent-default Passed
     [exec] Testing getmap:transparent-false (wms-1.3.0/d3717e372_1/d1097e56_1/d1097e341_1)...
     [exec] Assertion: When a GetMap request is made with TRANSPARENT=FALSE and a FORMAT that supports transparency over a layer that is not opaque, then the response contains no transparent pixels.
     [exec] Test getmap:transparent-false Passed
     [exec] Testing getmap:transparent-true (wms-1.3.0/d3717e372_1/d1097e56_1/d1097e345_1)...
     [exec] Assertion: When a GetMap request is made with TRANSPARENT=TRUE and a FORMAT that supports transparency over a BBOX that is not completely covered, then the response contains transparent pixels.
     [exec] Test getmap:transparent-true Passed
     [exec] Testing getmap:transparent-opaque-layer (wms-1.3.0/d3717e372_1/d1097e56_1/d1097e348_1)...
     [exec] Assertion: Clients may request TRANSPARENT=TRUE on a layer that is opaque.
     [exec] No named opaque layers.
     [exec] Test getmap:transparent-opaque-layer Passed
     [exec] Test getmap:transparent Passed
     [exec] Testing getmap:width-and-height (wms-1.3.0/d3717e372_1/d1097e61_1)...
     [exec] Assertion: The WIDTH and HEIGHT parameters behaves properly.
     [exec] Testing getmap:large-size (wms-1.3.0/d3717e372_1/d1097e61_1/d1097e362_1)...
     [exec] Assertion: When a request is made for a large map (1024x768 or largest map supported), the image returned is exactly the size requested.
     [exec] Test getmap:large-size Passed
     [exec] Testing getmap:small-size (wms-1.3.0/d3717e372_1/d1097e61_1/d1097e364_1)...
     [exec] Assertion: When a request is made with WIDTH=8 and HEIGHT=5, the image returned is exactly the size requested.
     [exec] Test getmap:small-size Passed
     [exec] Test getmap:width-and-height Passed
     [exec] Test getmap:main Passed
     [exec] Testing getfeatureinfo:main (wms-1.3.0/d3717e379_1)...
     [exec] Assertion: The GetFeatureInfo request behaves properly.
     [exec] Testing getfeatureinfo:exceptions (wms-1.3.0/d3717e379_1/d2546e30_1)...
     [exec] Assertion: The EXCEPTIONS parameter behaves properly.
     [exec] Testing getfeatureinfo:exceptions-default (wms-1.3.0/d3717e379_1/d2546e30_1/d2546e74_1)...
     [exec] Assertion: When an exception is raised and the EXCEPTIONS parameter is absent from the request, then the response is a valid exception with a Content-type header of text/xml.
     [exec] Test getfeatureinfo:exceptions-default Passed
     [exec] Testing getfeatureinfo:exceptions-xml (wms-1.3.0/d3717e379_1/d2546e30_1/d2546e76_1)...
     [exec] Assertion: When an exception is raised and EXCEPTIONS=XML, then the response is a valid exception with a Content-type header of text/xml.
     [exec] Test getfeatureinfo:exceptions-xml Passed
     [exec] Test getfeatureinfo:exceptions Passed
     [exec] Testing getfeatureinfo:feature_count (wms-1.3.0/d3717e379_1/d2546e47_1)...
     [exec] Assertion: The FEATURE_COUNT parameter behaves properly.
     [exec] Testing getfeatureinfo:feature_count-default (wms-1.3.0/d3717e379_1/d2546e47_1/d2546e94_1)...
     [exec] Assertion: When the FEATURE_COUNT parameter is not specified, then less data is returned than when FEATURE_COUNT is 2.
     [exec] Test getfeatureinfo:feature_count-default Passed
     [exec] Testing getfeatureinfo:feature_count-1 (wms-1.3.0/d3717e379_1/d2546e47_1/d2546e96_1)...
     [exec] Assertion: When the FEATURE_COUNT parameter is 1, then less data is returned than when FEATURE_COUNT is 2.
     [exec] Test getfeatureinfo:feature_count-1 Passed
     [exec] Test getfeatureinfo:feature_count Passed
     [exec] Testing getfeatureinfo:info_format (wms-1.3.0/d3717e379_1/d2546e52_1)...
     [exec] Assertion: The FORMAT parameter behaves properly.
     [exec] Testing getfeatureinfo:invalid-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e111_1)...
     [exec] Assertion: When a GetFeatureInfo request is made with an invalid INFO_FORMAT parameter, then the server returns an exception (code=InvalidFormat).
     [exec] Test getfeatureinfo:invalid-info_format Passed
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_1)...
     [exec] Assertion: For format "text/plain", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Test getfeatureinfo:each-info_format Passed
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_2)...
     [exec] Assertion: For format "application/vnd.ogc.gml", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_3)...
     [exec] Assertion: For format "application/vnd.ogc.gml/3.1.1", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Test getfeatureinfo:each-info_format Failed
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_4)...
     [exec] Assertion: For format "text/html", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_5)...
     [exec] Assertion: For format "application/json", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Testing getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_6)...
     [exec] Assertion: For format "text/javascript", when the INFO_FORMAT parameter is set to that format, the MIME type of the response matches that format.
     [exec] Test getfeatureinfo:info_format Failed (Inherited failure)
     [exec] Testing getfeatureinfo:i-and-j (wms-1.3.0/d3717e379_1/d2546e54_1)...
     [exec] Assertion: The I and J parameters behaves properly.
     [exec] Testing getfeatureinfo:invalid-i (wms-1.3.0/d3717e379_1/d2546e54_1/d2546e137_1)...
     [exec] Assertion: When a GetFeatureInfo request is made with an invalid I parameter, then the response is an exception (code=InvalidPoint).
     [exec] Test getfeatureinfo:invalid-i Passed
     [exec] Testing getfeatureinfo:invalid-j (wms-1.3.0/d3717e379_1/d2546e54_1/d2546e139_1)...
     [exec] Assertion: When a GetFeatureInfo request is made with an invalid J parameter, then the response is an exception (code=InvalidPoint).
     [exec] Test getfeatureinfo:invalid-j Passed
     [exec] Test getfeatureinfo:i-and-j Passed
     [exec] Testing getfeatureinfo:query-layers (wms-1.3.0/d3717e379_1/d2546e56_1)...
     [exec] Assertion: The QUERY_LAYERS parameter behaves properly.
     [exec] Testing getfeatureinfo:two-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e154_1)...
     [exec] Assertion: When a GetFeatureInfo request contains two layers, then the response is valid.
     [exec] Test getfeatureinfo:two-query_layers Passed
     [exec] Testing getfeatureinfo:three-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e156_1)...
     [exec] Assertion: When a GetFeatureInfo request contains three layers, then the response is valid.
     [exec] Test getfeatureinfo:three-query_layers Passed
     [exec] Testing getfeatureinfo:less-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e158_1)...
     [exec] Assertion: When a GetFeatureInfo request contains fewer layers in the QUERY_LAYERS parameter than it does in the LAYERS parameter, then the response is valid.
     [exec] Test getfeatureinfo:less-query_layers Passed
     [exec] Testing getfeatureinfo:invalid-query_layers (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e160_1)...
     [exec] Assertion: When a layer requested is not contained in the Capabilities XML of the WMS, then the server issues a Service Exception (code=LayerNotDefined).
     [exec] Test getfeatureinfo:invalid-query_layers Passed
     [exec] Testing getfeatureinfo:query_layers-not-queryable (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e162_1)...
     [exec] Assertion: When GetFeatureInfo is requested on a Layer that is not queryable, then the server issues a Service Exception (code=LayerNotQueryable).
     [exec] No named layers that are not queryable.
     [exec] Test getfeatureinfo:query_layers-not-queryable Passed
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_1)...
     [exec] Assertion: For layer "cite:Autos", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Test getfeatureinfo:each-queryable-layer Passed
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_2)...
     [exec] Assertion: For layer "cite:BasicPolygons", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_3)...
     [exec] Assertion: For layer "cite:Bridges", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_4)...
     [exec] Assertion: For layer "cite:BuildingCenters", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_5)...
     [exec] Assertion: For layer "cite:Buildings", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_6)...
     [exec] Assertion: For layer "cite:DividedRoutes", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_7)...
     [exec] Assertion: For layer "cite:Forests", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_8)...
     [exec] Assertion: For layer "cite:Lakes", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_9)...
     [exec] Assertion: For layer "cite:LakesWithElevation", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_10)...
     [exec] Assertion: For layer "cite:MapNeatline", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_11)...
     [exec] Assertion: For layer "cite:NamedPlaces", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_12)...
     [exec] Assertion: For layer "cite:Ponds", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_13)...
     [exec] Assertion: For layer "cite:RoadSegments", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Testing getfeatureinfo:each-queryable-layer (wms-1.3.0/d3717e379_1/d2546e56_1/d2546e169_14)...
     [exec] Assertion: For layer "cite:Streams", when the QUERY_LAYERS parameter is set to that layer name, the MIME type of the response is valid.
     [exec] Test getfeatureinfo:query-layers Passed
     [exec] Test getfeatureinfo:main Failed (Inherited failure)
     [exec] Testing recomendations:main (wms-1.3.0/d3717e386_1)...
     [exec] Assertion: If the "Check Recommendations" option was selected, the server supports fuctionality which is recommended in the spec, but not required.
     [exec] Testing recomendations:service-keywords (wms-1.3.0/d3717e386_1/d2997e13_1)...
     [exec] Assertion: The capabilities document includes a list of keywords or keyword phrases describing the server.
     [exec] Test recomendations:service-keywords Passed
     [exec] Testing recomendations:service-contact-info (wms-1.3.0/d3717e386_1/d2997e15_1)...
     [exec] Assertion: The capabilities document includes contact information.
     [exec] Test recomendations:service-contact-info Passed
     [exec] Testing recomendations:png-getmap-format (wms-1.3.0/d3717e386_1/d2997e17_1)...
     [exec] Assertion: The server advertises the image/png format for the GetMap operation.
     [exec] Test recomendations:png-getmap-format Passed
     [exec] Testing recomendations:layer-abstracts (wms-1.3.0/d3717e386_1/d2997e19_1)...
     [exec] Assertion: Each Layer in the capabilities document contains an abstract.
     [exec] Test recomendations:layer-abstracts Passed
     [exec] Testing recomendations:layer-keywordlists (wms-1.3.0/d3717e386_1/d2997e21_1)...
     [exec] Assertion: Each Layer in the capabilities document contains a keyword list.
     [exec] Test recomendations:layer-keywordlists Passed
     [exec] Testing recomendations:layer-crs (wms-1.3.0/d3717e386_1/d2997e24_1)...
     [exec] Assertion: All layers in the capabilities document are available in the CRS:84 and/or EPSG:4326 CRS.
     [exec] Test recomendations:layer-crs Passed
     [exec] Testing recomendations:metadataurls (wms-1.3.0/d3717e386_1/d2997e26_1)...
     [exec] Assertion: Every named Layer in the capabilities document contains a MetadataURL element.
     [exec] Test recomendations:metadataurls Passed
     [exec] Testing recomendations:dims-no-whitespace (wms-1.3.0/d3717e386_1/d2997e28_1)...
     [exec] Assertion: No dimension name values in the capabilities document contain whitespace.
     [exec] Test recomendations:dims-no-whitespace Passed
     [exec] Testing recomendations:dims-defaults (wms-1.3.0/d3717e386_1/d2997e30_1)...
     [exec] Assertion: Each dimension declaration in the capabilities document contains a default value.
     [exec] Test recomendations:dims-defaults Passed
     [exec] Test recomendations:main Passed
     [exec] Testing dims:main (wms-1.3.0/d3717e389_1)...
     [exec] Assertion: Support for dimensional data is correct.
     [exec] Testing dims:missing-no-default (wms-1.3.0/d3717e389_1/d3067e182_1)...
     [exec] Assertion: When a layer that has a dimension without a default value is requested without supplying the dimension parameter, the response is an exception with code=MissingDimensionValue.
     [exec] No Named layers that have a dimension without a default value.
     [exec] Test dims:missing-no-default Passed
     [exec] Test dims:main Passed
     [exec] Test main:main Failed (Inherited failure)
     [exec] Suite wms-1.3.0:compliance_suite Failed
     [copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-master/ws/tools/users/geoserver/wms-1.3.0&gt;
BUILD SUCCESSFUL
Total time: 50 seconds
+ ant wms-1.3-log
+ grep Failed
     [exec] Test main:main (wms-1.3.0) Failed (Inherited Failure)
     [exec] Test getfeatureinfo:main (wms-1.3.0/d3717e379_1) Failed (Inherited Failure)
     [exec] Test getfeatureinfo:info_format (wms-1.3.0/d3717e379_1/d2546e52_1) Failed (Inherited Failure)
     [exec] Test getfeatureinfo:each-info_format (wms-1.3.0/d3717e379_1/d2546e52_1/d2546e117_3) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
<http://hudson.opengeo.org/hudson/job/cite-wms-1.3-master/ws/&gt;
+ pushd geoserver/geoserver-2.3-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wms-1.3-master/ws/geoserver/geoserver-2.3-SNAPSHOT/bin&gt; <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-master/ws/&gt;
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ ./shutdown.sh
+ sleep 2
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
See <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-master/517/&gt;
