[Geoserver-devel] [Hudson] Build failed in Hudson: cite-wms-1.3-trunk #377
See <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/377/&gt;
[...truncated 1166 lines...]
    [javac] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/setup/UserFilesRealm/build&gt;
Note: <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/setup/UserFilesRealm/src/java/com/occamlab/te/realm/UserFilesRealm.java&gt; uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
     [copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/setup/UserFilesRealm/build/com/occamlab/te/realm&gt;
jar:
      [jar] Building jar: <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/setup/UserFilesRealm/UserFilesRealm.jar&gt;
zip.manager.bin:
   [delete] Deleting directory <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/build&gt;
    [mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/build&gt;
    [mkdir] Created dir: <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/build/teamengine-2012.06.12&gt;
     [copy] Copying 2 files to <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/build/teamengine-2012.06.12&gt;
      [zip] Building zip: <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/zips/teamengine-manager-2012.06.12-bin.zip&gt;
[INFO] Executed tasks
[WARNING] Using platform encoding (UTF-8 actually) to copy filtered resources, i.e. build is platform dependent!
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/src/test/resources&gt;
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/target/cite-1.0.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/target/cite-1.0.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/cite/1.0/cite-1.0.jar
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 23 seconds
[INFO] Finished at: Tue Jun 12 16:33:19 UTC 2012
[INFO] Final Memory: 46M/364M
+ ant clean
Buildfile: <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/build.xml&gt;
clean:
BUILD SUCCESSFUL
Total time: 1 second
+ pushd ..
<http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/&gt; <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools&gt; <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/&gt;
++ pwd
+ FORMS=<http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/forms&gt;
+ popd
+ ant -Dcite.headless=true -Dcite.headless.formroot=<http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/forms&gt; wms-1.3
wms-1.3:
run-test:
     [exec] Jun 12, 2012 4:33:23 PM com.occamlab.te.Generator generateXsl
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/parsers.ctl&gt;
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/apps/engine/resources/com/occamlab/te/scripts/functions.ctl&gt;
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/functions.xml&gt;
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/interactive.xml&gt;
     [exec] Jun 12, 2012 4:33:24 PM com.occamlab.te.Generator generateXsl
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/basic_elements.xml&gt;
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/getcapabilities.xml&gt;
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/getmap.xml&gt;
     [exec] Jun 12, 2012 4:33:25 PM com.occamlab.te.Generator generateXsl
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/getfeatureinfo.xml&gt;
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/recommendations.xml&gt;
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/dimensions.xml&gt;
     [exec] Jun 12, 2012 4:33:26 PM com.occamlab.te.Generator generateXsl
     [exec] INFO: Validating <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/engine/scripts/wms-1.3.0/ctl/main.xml&gt;
     [exec] Checking for <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/forms/wms-1.3.0.xml&gt;
     [exec] Testing suite wms-1.3.0:compliance_suite...
     [exec] Testing main:main (wms-1.3.0)...
     [exec] Assertion: The implementation under test complies with the WMS 1.3.0 specification.
     [exec] Error
     [exec] SXXP0003: Error reported by XML parser: Premature end of file.
     [exec] Jun 12, 2012 4:34:55 PM com.occamlab.te.TECore parse
     [exec] SEVERE: parse Error
     [exec] net.sf.saxon.trans.XPathException: org.xml.sax.SAXParseException: Premature end of file.
     [exec] at net.sf.saxon.event.Sender.sendSAXSource(Sender.java:379)
     [exec] at net.sf.saxon.event.Sender.send(Sender.java:185)
     [exec] at net.sf.saxon.IdentityTransformer.transform(IdentityTransformer.java:29)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1502)
     [exec] at com.occamlab.te.TECore.parse(TECore.java:1486)
     [exec] at com.occamlab.te.TECore.request(TECore.java:1123)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [exec] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
     [exec] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
     [exec] at java.lang.reflect.Method.invoke(Method.java:597)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:533)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:256)
     [exec] at net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:147)
     [exec] at net.sf.saxon.expr.PathExpression.iterate(PathExpression.java:848)
     [exec] at net.sf.saxon.sort.DocumentSorter.iterate(DocumentSorter.java:84)
     [exec] at net.sf.saxon.instruct.CopyOf.processLeavingTail(CopyOf.java:292)
     [exec] at net.sf.saxon.instruct.Instruction.process(Instruction.java:94)
     [exec] at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:282)
     [exec] at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:295)
     [exec] at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:341)
     [exec] at net.sf.saxon.expr.LetExpression.process(LetExpression.java:372)
     [exec] at net.sf.saxon.instruct.ForEach.processLeavingTail(ForEach.java:300)
     [exec] at net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:551)
     [exec] at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:175)
     [exec] at net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:343)
     [exec] at net.sf.saxon.Controller.transformDocument(Controller.java:1736)
     [exec] at net.sf.saxon.Controller.transform(Controller.java:1560)
     [exec] at net.sf.saxon.s9api.XsltTransformer.transform(XsltTransformer.java:190)
     [exec] at com.occamlab.te.TECore.executeTemplate(TECore.java:403)
     [exec] at com.occamlab.te.TECore.executeTest(TECore.java:530)
     [exec] at com.occamlab.te.TECore.execute_test(TECore.java:278)
     [exec] at com.occamlab.te.TECore.execute_suite(TECore.java:310)
     [exec] at com.occamlab.te.TECore.execute(TECore.java:233)
     [exec] at com.occamlab.te.Test.main(Test.java:275)
     [exec] Caused by: org.xml.sax.SAXParseException: Premature end of file.
     [exec] at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
     [exec] at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknown Source)
     [exec] at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
     [exec] at org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown Source)
     [exec] at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
     [exec] at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
     [exec] at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
     [exec] at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
     [exec] at net.sf.saxon.event.Sender.sendSAXSource(Sender.java:371)
     [exec] ... 33 more
     [exec] ---------
     [exec] org.xml.sax.SAXParseException: Premature end of file.
     [exec] Error: The capabilities document does not contain a root element named WMS_Capabilities in the "http://www.opengis.net/wms&quot; namespace.
     [exec] Further processing suspended.
     [exec] Test main:main Failed
     [exec] Suite wms-1.3.0:compliance_suite Failed
     [copy] Copying 1 file to <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/tools/users/geoserver/wms-1.3.0&gt;
BUILD SUCCESSFUL
Total time: 1 minute 34 seconds
+ ant wms-1.3-log
+ grep Failed
     [exec] Test main:main (wms-1.3.0) Failed
+ '[' 0 == 0 ']'
+ RETURN=1
+ echo RETURN=1
RETURN=1
+ popd
+ pushd geoserver/geoserver-2.2-SNAPSHOT/bin
<http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/geoserver/geoserver-2.2-SNAPSHOT/bin&gt; <http://hudson.opengeo.org/hudson/job/cite-wms-1.3-trunk/ws/&gt;
+ popd
+ ONLINE=1
+ (( i = 1 ))
+ (( i <= 100 ))
+ sleep 2
+ ./shutdown.sh
+ echo 'Pinging GeoServer at http://localhost:11010/geoserver
+ curl -G http://localhost:11010/geoserver
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:06 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:07 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:08 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:09 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:10 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:11 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:12 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:13 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:14 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:15 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:16 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:17 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:18 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:19 --:--:-- 0
  0 0 0 0 0 0 0 0 --:--:-- 0:00:20 --:--:-- 0
+ '[' 0 '!=' 0 ']'
+ (( i++ ))
+ (( i <= 100 ))
+ sleep 2
curl: (7) couldn't connect to host
+ '[' 7 '!=' 0 ']'
+ ONLINE=0
+ break
+ '[' 0 == 1 ']'
+ echo 'GeoServer is offline'
+ exit 1
