See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/728/>
[...truncated 34119 lines...]
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Image Mosaic JDBC Extension
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile/2.7-SNAPSHOT/gt-shapefile-2.7-SNAPSHOT.jar
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/src/test/java>
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/control-flow>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/control-flow/src/main/resources>
Downloading: http://repo.opengeo.org//org/geotools/ogc/org.w3.xlink/2.7-SNAPSHOT/org.w3.xlink-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml2/2.7-SNAPSHOT/gt-xsd-gml2-2.7-SNAPSHOT.jar
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/control-flow/target/classes>
[INFO] Copying 0 resource
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/control-flow/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/control-flow/target/surefire-reports>
T E S T S
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-3,5,main] calling requestIncoming
Thread[Thread-3,5,main] waiting
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-5,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] waiting
sleep interrupted
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-5,5,main] waiting
sleep interrupted
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.103 sec <<< FAILURE!
Running org.geoserver.flow.controller.SingleIpFlowControllerTest
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
sleep interrupted
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Thread[Thread-9,5,main] calling requestIncoming
Thread[Thread-9,5,main] waiting
Thread[Thread-9,5,main] calling requestComplete
Thread[Thread-9,5,main] done
Thread[Thread-10,5,main] calling requestIncoming
Thread[Thread-10,5,main] waiting
Thread[Thread-11,5,main] calling requestIncoming
Thread[Thread-11,5,main] waiting
sleep interrupted
Thread[Thread-10,5,main] calling requestComplete
Thread[Thread-10,5,main] done
sleep interrupted
Thread[Thread-11,5,main] calling requestComplete
Thread[Thread-11,5,main] done
Thread[Thread-12,5,main] calling requestIncoming
Thread[Thread-12,5,main] waiting
Thread[Thread-13,5,main] calling requestIncoming
Thread[Thread-13,5,main] waiting
sleep interrupted
Thread[Thread-12,5,main] calling requestComplete
Thread[Thread-12,5,main] done
sleep interrupted
Thread[Thread-13,5,main] calling requestComplete
Thread[Thread-13,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.247 sec
Running org.geoserver.flow.controller.IpBlacklistFilterTest
03 Jul 14:02:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/control-flow/./target/mock5215893296482045567data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.125 sec
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Running org.geoserver.flow.NestedRequestSentinelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-15,5,main] calling requestIncoming
Thread[Thread-15,5,main] waiting
Thread[Thread-15,5,main] calling requestComplete
Thread[Thread-15,5,main] done
Thread[Thread-16,5,main] calling requestIncoming
Thread[Thread-16,5,main] waiting
Thread[Thread-17,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-16,5,main] calling requestComplete
Thread[Thread-16,5,main] done
Thread[Thread-17,5,main] waiting
sleep interrupted
Thread[Thread-17,5,main] calling requestComplete
Thread[Thread-17,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.086 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.flow.controller.IpFlowControllerTest
Thread[Thread-18,5,main] calling requestIncoming
Thread[Thread-18,5,main] waiting
Thread[Thread-18,5,main] calling requestComplete
Thread[Thread-18,5,main] done
Thread[Thread-19,5,main] calling requestIncoming
Thread[Thread-19,5,main] waiting
Thread[Thread-20,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-19,5,main] calling requestComplete
Thread[Thread-19,5,main] done
Thread[Thread-20,5,main] waiting
sleep interrupted
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] calling requestIncoming
Thread[Thread-21,5,main] waiting
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
sleep interrupted
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.146 sec
Results :
Failed tests:
testTimeout(org.geoserver.flow.controller.GlobalFlowControllerTest)
Tests run: 18, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/extension/control-flow/target/surefire-reports> for the individual test results.
[INFO] Total time: 12 minutes
[INFO] Finished at: Tue Jul 03 14:03:01 UTC 2012
[INFO] Final Memory: 76M/235M
