[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.1.x #730
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/730/changes&gt;
Changes:
[jdeolive] GEOS-5200, adding .gitignore files
[jdeolive] changing default configDirectory value to point out to data directory three levels out
[jdeolive] GEOS-5200, updating revision info to use git-commit-id plugin, and removed references to all svn revisions
[jdeolive] GEOS-5200, updating documentation to reflect switch to git
Started by an SCM change
Checkout:workspace / <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 63f572d8381ffcc26518376b93a53199c471d1a9 (origin/2.1.x)
Fetching changes from the remote Git repository
Fetching upstream changes from git://github.com/geoserver/geoserver.git
Commencing build of Revision c9bdb75c3a290031883abab06a7e9a64c13f3c73 (origin/2.1.x)
Checking out Revision c9bdb75c3a290031883abab06a7e9a64c13f3c73 (origin/2.1.x)
[workspace] $ /opt/apache-maven-2.2.1/bin/mvn -f src/pom.xml -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing clean install -DconfigDirectory=../../../data
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] GeoServer Maven Archetypes
[INFO] GeoServer Web Plugin Archetype
[INFO] GeoServer WFS Output Format Archetype
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] Building GeoServer
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/target&gt;
this realm = app0.child-container[pl.project13.maven:git-commit-id-plugin:2.0.4]
urls[0] = file:/usr/share/jetty/.m2/repository/pl/project13/maven/git-commit-id-plugin/2.0.4/git-commit-id-plugin-2.0.4.jar
urls[1] = file:/usr/share/jetty/.m2/repository/org/codehaus/plexus/plexus-utils/1.1/plexus-utils-1.1.jar
urls[2] = file:/usr/share/jetty/.m2/repository/com/madgag/org.eclipse.jgit/1.0.99.0.7-UNOFFICIAL-ROBERTO-RELEASE/org.eclipse.jgit-1.0.99.0.7-UNOFFICIAL-ROBERTO-RELEASE.jar
Number of imports: 10
import: org.codehaus.classworlds.Entry@anonymised.com
this realm = plexus.core
urls[0] = file:/opt/apache-maven-2.2.1/lib/maven-2.2.1-uber.jar
[ERROR] BUILD ERROR
[INFO] Internal error in the plugin manager executing goal 'pl.project13.maven:git-commit-id-plugin:2.0.4:revision': Unable to find the mojo 'revision' (or one of its required components) in the plugin 'pl.project13.maven:git-commit-id-plugin'
Bad version number in .class file
[INFO] Total time: 3 seconds
[INFO] Finished at: Wed Jul 04 21:36:18 UTC 2012
[INFO] Final Memory: 22M/162M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/731/changes&gt;
Changes:
[jdeolive] fixing typo in checkout docs, co -> clone
Last Built Revision: Revision c9bdb75c3a290031883abab06a7e9a64c13f3c73 (origin/2.1.x)
Commencing build of Revision d2f5935ac4f11f327e3e8711c1a59c479d1123fc (origin/2.1.x)
Checking out Revision d2f5935ac4f11f327e3e8711c1a59c479d1123fc (origin/2.1.x)
[INFO] GeoServer
[INFO] Main Module
[ERROR] BUILD ERROR
[INFO] Total time: 5 seconds
[INFO] Finished at: Wed Jul 04 23:09:05 UTC 2012
[INFO] Final Memory: 21M/162M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/732/changes&gt;
