See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/744/changes>
Changes:
[Daniele Romagnoli] GEOS-5227: validate pool sizes changes on submit
[...truncated 20974 lines...]
"DejaVu Sans Mono",
"SansSerif.plain",
"Monospaced",
"DialogInput",
"Lucida Sans Typewriter",
"Dialog",
"Dialog.bolditalic",
"Serif",
"SansSerif.bolditalic",
"Lucida Sans Typewriter Regular",
"Lucida Sans",
"DejaVu Sans",
"DialogInput.bolditalic",
"Serif.plain",
"Serif.italic",
"DialogInput.plain",
"DejaVu Serif Bold",
"Serif.bolditalic",
"Monospaced.plain",
"Monospaced.bold",
"Lucida Bright Italic",
"Lucida Sans Typewriter Bold",
"Monospaced.italic",
"Lucida Bright",
"DialogInput.bold",
"Monospaced.bolditalic",
"Dialog.plain",
"Serif.bold",
"DejaVu Serif",
"Lucida Sans Demibold"
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.75 sec
Running org.geoserver.catalog.rest.StyleTest
18 Jul 16:36:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock9153749350433233253data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock1291929008699837074data>
18 Jul 16:36:10 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock1965147412767477796data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock7131267142706161337data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock4394090221823172779data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock7601199399842262768data>
18 Jul 16:36:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock6761795889914754960data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock1243962540357788528data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock7600449536475815323data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock3690373914806611448data>
18 Jul 16:36:12 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock2031099674213482399data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock7002844440175538028data>
18 Jul 16:36:12 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.StyleResource.handleObjectDelete(StyleResource.java:218)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:224)
at org.restlet.Finder.handle(Finder.java:300)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:531)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1185)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1204)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1139)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1121)
at org.geoserver.test.GeoServerAbstractTestSupport.deleteAsServletResponse(GeoServerAbstractTestSupport.java:754)
at org.geoserver.catalog.rest.StyleTest.testDeleteWithLayerReference(StyleTest.java:168)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock3244281357550783617data>
18 Jul 16:36:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock4745283052307661926data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock3264077078045654957data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock3237659066647160229data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock6531828272311495323data>
18 Jul 16:36:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/./target/mock8527116317296942996data>
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.833 sec
Results :
Tests run: 201, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.1-SNAPSHOT/restconfig-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.1-SNAPSHOT/restconfig-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.1-SNAPSHOT/restconfig-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/restconfig/target/restconfig-2.1-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.1-SNAPSHOT/restconfig-2.1-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/target>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/target/web-2.1-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/web/2.1-SNAPSHOT/web-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/target/web-2.1-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/2.1-SNAPSHOT/web-2.1-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/core/target>
[INFO] Copying 5 resources
[INFO] Copying 379 resources
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] [antrun:run {execution: process-resources}]
[INFO] Executing tasks
[INFO] Executed tasks
[INFO] Compiling 197 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/core/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/core/src/main/java/org/geoserver/web/admin/CoverageAccessPage.java>:\[61,57\] cannot find symbol
symbol : method isEmpty()
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/web/core/src/main/java/org/geoserver/web/admin/CoverageAccessPage.java>:\[61,80\] cannot find symbol
[INFO] Total time: 6 minutes 42 seconds
[INFO] Finished at: Wed Jul 18 16:36:22 UTC 2012
[INFO] Final Memory: 61M/220M
