See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/748/changes>
Changes:
[Daniele Romagnoli] GEOS-5231: Document the coverage settings page
Started by an SCM change
Checkout:workspace / <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/> - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision dbf6c4588990fff3ee33926fcca01cb531a6adcd (origin/2.1.x)
Fetching changes from the remote Git repository
Fetching upstream changes from git://github.com/geoserver/geoserver.git
Commencing build of Revision 8d4edcc2d5c1852240d7fed02f5436fa273a124f (origin/2.1.x)
Checking out Revision 8d4edcc2d5c1852240d7fed02f5436fa273a124f (origin/2.1.x)
[workspace] $ /opt/apache-maven-2.2.1/bin/mvn -f src/pom.xml -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing clean install -DconfigDirectory=../../../data
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] GeoServer Maven Archetypes
[INFO] GeoServer Web Plugin Archetype
[INFO] GeoServer WFS Output Format Archetype
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] Building GeoServer
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/target>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:2.7-SNAPSHOT: checking for updates from opengeo
[WARNING] repository metadata for: 'snapshot org.geotools:gt-api:2.7-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: Error transferring file: repo.opengeo.org
[INFO] Repository 'opengeo' will be blacklisted
[INFO] snapshot org.geotools:gt-api:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-opengis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-opengis:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-opengis:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-main:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/target/geoserver-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/target/geoserver-2.1-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/maven/target>
Downloading: http://repo.opengeo.org//org/geotools/gt-opengis/2.7-SNAPSHOT/gt-opengis-2.7-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
org.geotools:gt-opengis:jar:2.7-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
geosolutions (http://maven.geo-solutions.it/),
maven2-repository.dev.java.net (http://download.java.net/maven/2),
opengeo (http://repo.opengeo.org/),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org)
Path to dependency:
1) org.geoserver:maven:pom:2.1-SNAPSHOT
2) org.geotools:gt-api:jar:2.7-SNAPSHOT
3) org.geotools:gt-referencing:jar:2.7-SNAPSHOT
4) org.geotools:gt-metadata:jar:2.7-SNAPSHOT
5) org.geotools:gt-opengis:jar:2.7-SNAPSHOT
[INFO] Total time: 33 seconds
[INFO] Finished at: Tue Jul 24 12:37:00 UTC 2012
[INFO] Final Memory: 34M/157M
