See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/816/changes>
Changes:
[Andrea Aime] [GEOS-5395] Catalog reload breaks GWC integration, update sequence upgrade and namespace/workspace consistency
[...truncated 742 lines...]
[INFO] Copying 4 resources
Downloading: http://repo.opengeo.org//org/geotools/ogc/org.w3.xlink/2.7-SNAPSHOT/org.w3.xlink-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-metadata/2.7-SNAPSHOT/gt-metadata-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-opengis/2.7-SNAPSHOT/gt-opengis-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-graph/2.7-SNAPSHOT/gt-graph-2.7-SNAPSHOT.jar
[INFO] Compiling 19 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/surefire-reports>
T E S T S
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Nov 18, 2012 8:36:26 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.44 sec
Running org.geoserver.ows.DispatcherTest
Nov 18, 2012 8:36:26 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: display name [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]; startup date [Sun Nov 18 20:36:26 UTC 2012]; root of context hierarchy
Nov 18, 2012 8:36:26 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Nov 18, 2012 8:36:26 PM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
Nov 18, 2012 8:36:26 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.36 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.049 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.ows.kvp.FormatOptionsKvpParserTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Results :
Tests run: 35, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/ows/target/ows-2.1-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/main/target>
[INFO] Copying 28 resources
[INFO] Copying 146 resources
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/2.7-SNAPSHOT/gt-jdbc-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-epsg-hsql/2.7-SNAPSHOT/gt-epsg-hsql-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-wms:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/gt-xml/2.7-SNAPSHOT/gt-xml-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/2.7-SNAPSHOT/gt-wfs-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:unsupported:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-wfs/2.7-SNAPSHOT/gt-xsd-wfs-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/2.7-SNAPSHOT/net.opengis.wfs-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/2.7-SNAPSHOT/gt-xsd-fes-2.7-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/gt-api/2.7-SNAPSHOT/gt-api-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-ows/2.7-SNAPSHOT/gt-xsd-ows-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-core/2.7-SNAPSHOT/gt-xsd-core-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/2.7-SNAPSHOT/gt-jdbc-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-epsg-hsql/2.7-SNAPSHOT/gt-epsg-hsql-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-xml/2.7-SNAPSHOT/gt-xml-2.7-SNAPSHOT.jar
[INFO] Compiling 321 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/main/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/src/main/src/main/java/org/geoserver/catalog/impl/CatalogImpl.java>:\[1113,5\] method does not override a method from its superclass
[INFO] Total time: 53 seconds
[INFO] Finished at: Sun Nov 18 20:36:43 UTC 2012
[INFO] Final Memory: 49M/156M
