See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/655/>
Started by upstream project "geoserver-2.1.x" build number 740
[src] $ /opt/apache-maven-2.2.1/bin/mvn -U -Djava.awt.headless=true -DskipTests -DconfigDirectory=../../../data -P allExtensions,monitoring,proxy,printing,ftp deploy
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] GeoServer Maven Archetypes
[INFO] GeoServer Web Plugin Archetype
[INFO] GeoServer WFS Output Format Archetype
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Monitoring Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] Building GeoServer
[INFO] task-segment: [deploy]
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:2.7-SNAPSHOT: checking for updates from opengeo
[WARNING] repository metadata for: 'snapshot org.geotools:gt-api:2.7-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: Error transferring file: repo.opengeo.org
[INFO] Repository 'opengeo' will be blacklisted
[INFO] snapshot org.geotools:gt-api:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-referencing:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-metadata:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-opengis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-opengis:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-opengis:2.7-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-main:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Preparing source:jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/target/geoserver-2.1-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.1-SNAPSHOT/geoserver-2.1-SNAPSHOT-tests.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
[ERROR] BUILD ERROR
[INFO] Error retrieving previous build number for artifact 'org.geoserver:geoserver:pom': repository metadata for: 'snapshot org.geoserver:geoserver:2.1-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: repo.opengeo.org
[INFO] Total time: 19 seconds
[INFO] Finished at: Thu Jul 12 12:47:47 UTC 2012
[INFO] Final Memory: 33M/161M
