[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.1.x-deploy #669
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/669/&gt;
[...truncated 43556 lines...]
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/2.7-SNAPSHOT/net.opengis.ows-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-graph/2.7-SNAPSHOT/gt-graph-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-cql/2.7-SNAPSHOT/gt-cql-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/2.7-SNAPSHOT/gt-data-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/2.7-SNAPSHOT/gt-xsd-fes-2.7-SNAPSHOT.jar
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-test-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3e09bda07f671bb9c94717fb5bd3a700bc637a3d'; remote = '4f666603099475c0f70b7134c3b20c1dea742c50' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '3e09bda07f671bb9c94717fb5bd3a700bc637a3d'; remote = '4f666603099475c0f70b7134c3b20c1dea742c50' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT.jar
4/11K
8/11K
11/11K
15/11K
19/11K
22/11K
11K uploaded (querylayer-2.1-SNAPSHOT.jar)
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:querylayer:2.1-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:querylayer'
[INFO] Uploading project information for querylayer 2.1-SNAPSHOT
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'c25874414b92319aae2c316e8ed39e21e281d96c'; remote = '0842c8f8d30f382726b3e423a0c7d79ed71fb22a' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'c25874414b92319aae2c316e8ed39e21e281d96c'; remote = '0842c8f8d30f382726b3e423a0c7d79ed71fb22a' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-tests.jar
4/6K
6/6K
10/6K
12/6K
6K uploaded (querylayer-2.1-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-sources.jar
4/6K
6/6K
10/6K
13/6K
6K uploaded (querylayer-2.1-SNAPSHOT-sources.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-test-sources.jar
3/3K
6/3K
3K uploaded (querylayer-2.1-SNAPSHOT-test-sources.jar)
[INFO] Building Teradata DataStore Extension
[INFO] task-segment: [deploy]
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Nothing to compile - all classes are up to date
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/src/test/java&gt;
[INFO] No sources to compile
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-test-sources.jar
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '9141678dac7e785f3247b214090d0aaa98c1125e'; remote = 'bfa062c1cd6fa1c1c4df22235b519d092e3cb6c6' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '9141678dac7e785f3247b214090d0aaa98c1125e'; remote = 'bfa062c1cd6fa1c1c4df22235b519d092e3cb6c6' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT.jar
4/4K
4/4K
8/4K
8/4K
4K uploaded (teradata-2.1-SNAPSHOT.jar)
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:teradata'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:teradata:2.1-SNAPSHOT'
[INFO] Uploading project information for teradata 2.1-SNAPSHOT
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '76822748fbfc6c157613f48d5c3def1924c51542'; remote = 'fde0f746c2418846fd482b59c891f1445f894e7b' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '76822748fbfc6c157613f48d5c3def1924c51542'; remote = 'fde0f746c2418846fd482b59c891f1445f894e7b' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-tests.jar
1/1K
3/1K
1K uploaded (teradata-2.1-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-sources.jar
2/2K
4/2K
2K uploaded (teradata-2.1-SNAPSHOT-sources.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-test-sources.jar
327/327b
654/327b
327b uploaded (teradata-2.1-SNAPSHOT-test-sources.jar)
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [15.967s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [0.306s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [1.901s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [0.214s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [0.491s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [0.429s]
[INFO] Core Platform Module .................................. SUCCESS [0.439s]
[INFO] Open Web Service Module ............................... SUCCESS [5.656s]
[INFO] Main Module ........................................... SUCCESS [9.488s]
[INFO] Web Coverage Service Module ........................... SUCCESS [0.623s]
[INFO] Web Coverage Service 1.0 Module ....................... SUCCESS [2.337s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [1.218s]
[INFO] Web Feature Service Module ............................ SUCCESS [1.168s]
[INFO] Web Map Service Module ................................ SUCCESS [1.698s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.241s]
[INFO] REST Support Module ................................... SUCCESS [0.611s]
[INFO] REST Configuration Service Module ..................... SUCCESS [1.350s]
[INFO] GeoServer Web Modules ................................. SUCCESS [0.224s]
[INFO] Core UI Module ........................................ SUCCESS [4.866s]
[INFO] WMS UI Module ......................................... SUCCESS [2.110s]
[INFO] GWC UI Module ......................................... SUCCESS [0.829s]
[INFO] WFS UI Module ......................................... SUCCESS [0.741s]
[INFO] Demoes Module ......................................... SUCCESS [1.005s]
[INFO] WCS UI Module ......................................... SUCCESS [0.757s]
[INFO] Security UI Module .................................... SUCCESS [1.581s]
[INFO] Community Space ....................................... SUCCESS [0.236s]
[INFO] Printing Module ....................................... SUCCESS [0.612s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [1.472s]
[INFO] GeoServer Embedded FTP server ......................... SUCCESS [1.311s]
[INFO] GeoServer Monitoring Extension ........................ SUCCESS [3.232s]
[INFO] GeoServer Web Application ............................. SUCCESS [14.973s]
[INFO] GeoServer Extensions .................................. SUCCESS [0.495s]
[INFO] Application Schema Support ............................ SUCCESS [2.419s]
[INFO] Application Schema Integration Test ................... SUCCESS [3.305s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [0.811s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [1.920s]
[INFO] GeoSearch Index Module ................................ SUCCESS [0.786s]
[INFO] H2 DataStore Extension ................................ SUCCESS [0.624s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [0.496s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.306s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [0.489s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [0.471s]
[INFO] ImageMap Output Format ................................ SUCCESS [1.550s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [0.535s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [0.594s]
[INFO] Excel Output Format ................................... SUCCESS [0.649s]
[INFO] Validation Module ..................................... SUCCESS [0.505s]
[INFO] Chart external graphics support ....................... SUCCESS [0.582s]
[INFO] Feature Generalization Extension ...................... SUCCESS [0.677s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [1.396s]
[INFO] OWS request flow controller ........................... SUCCESS [0.552s]
[INFO] Web Processing Service parent ......................... SUCCESS [0.183s]
[INFO] Web Processing Service Module ......................... SUCCESS [2.808s]
[INFO] Web Processing Service GUI ............................ SUCCESS [1.552s]
[INFO] GeoServer Layer Querying filter functions ............. SUCCESS [0.526s]
[INFO] Teradata DataStore Extension .......................... SUCCESS [0.746s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 1 minute 48 seconds
[INFO] Finished at: Tue Aug 07 12:25:08 UTC 2012
[INFO] Final Memory: 77M/266M
[src] $ /bin/sh -xe /var/cache/jetty/data/hudson914110314815070133.sh
+ VER=2.1-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.1-SNAPSHOT.jar
+ sha1sum web-app-2.1-SNAPSHOT.jar
+ curl -u hudson:chrono44logic -T web-app-2.1-SNAPSHOT.jar http://repo.opengeo.org/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT.jar
curl: (6) Couldn't resolve host 'repo.opengeo.org'
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/670/&gt;
